Drive around the water box, not through it with your street tires.
Leave when you see the amber above the green flash. That will improve your reaction times. You want to be cutting .09-.04 lights. Or at least .1's. With a .321 reaction time you'll most often lose..
Looks like your running close to your dial which is a good thing. Means your driving and car is pretty consistant.
I usually put 2/100's under my best qualifiying run for a dial and hope I don't break out! Some guys like to put a higher dial than they run on and try to hit the brakes at the end. I'd rather run flat out
Try shifting at about 5300 rpms.
Is your timing advanced or doesn't the hypertech chip do that.
Good luck
Have fun
