Here's a Question
  • Thread starter Thread starter darkness falls
  • Start date Start date Mar 5, 2004
darkness falls
112
Kansas
Mar 5, 2004
  • Mar 5, 2004
What would be a good air compressor to use, 3hp or 5, 90psi or 125psi....
thanks for the previous replies at my posts.
"***Update***" \n;
the car is completely stripped and I will be starting body repair inside the car and new floors will be installed later on this month. Found some at my parents house that have been there for 4 years.
2nd Mustang
2,488
Southern California
Mar 5, 2004
  • Mar 5, 2004
I have a 2 hp, 8 gallon 90 psi, oiled compressor. It's just enough for light work. Anything serious probably will need a larger/more powerful setup. Don't forget a dedicated A.C. outlet as they draw a lot of juice.
67GTA-FB429
777
Tri-Cities, Wa
Mar 5, 2004
  • Mar 5, 2004
I have a 22gal, 125psi compressor and it is not enough if you are doing body work. Get the biggest one that you can afford and fit in your garage. I wish I had at least double capacity, the pressure is ok.
allcarfan
The Answer Man
2,458
North Atlanta
Mar 5, 2004
  • Mar 5, 2004
I have a 35 gallon, 6hp compressor. 125PSI. although, most of my airtools run from 60-80 PSI. A compressor of this size constantly runs while using a die grinder for an extended period of time and will run constantly if sandblasting.
speedy66
629
glendale,arizona,usa
Mar 5, 2004
  • Mar 5, 2004
I have one of the huge 60 gal.. stand up units.. 5 hp, 130 psi.. go bigger.. i used to have a one on wheels it was a joke.. sand for 3 minutes let it fill for 5 minutes..
Go BIG.
  • B0udreaux
  • Jul 14, 2026
AeroCoupe
SOLD 1986 Mercury Capri 5.0 5-speed
  • blackmerc
  • Jul 29, 2026
Fox Body Mustangs For Sale (1979-93) Aug 24, 2026
General karthief
M
  • mnky99
  • Sep 5, 2025
mnky99
M
R
  • riored97snake
  • Jun 18, 2026
  • What is it Worth?!?!?
riored97snake
R
  • dan50
  • Jul 18, 2026
dan50
