- Oct 21, 2006
- 322
- 4
- 18
You guys can tell me how full of crap I am.
93 mustang notch
2.3, 5 speed, 7.5 rearend
budget .50 cents
I have lying around misc parts from a 99 gt that might be used.
1. Springs -99Gt with cut coils
2. rear sway bar -99gt
3. front sway bar- either from a GT or maybe a Fairmont wagon, whatever I have to choose from (about 25 of them).
4. brakes- stock with a good rebuild, stainless lines and new rotors - (The reason behind this is that I think that the little 10.5 brakes were actually used on V8 cars. )
5. Granatelli or QA-1 front k-member, (some of the drag race oriented k-members move the front end out too much) these can be used witht he stock control arms. (I need to know if they are also compatible with the 2.3 front control arms)
6. Steeda lower ball joint kit and bump steer kit along with the upper alignment plates.
7. subframe connectors
8. Fabricated panhard bar and upper control arms for the rear.
9. 3.73 gear and posi (probably used).
If all this sounds doable for a weekend warrior auto cross car let me know. Also let me know of a better/cheaper way to do it or if I might run into compatibility issues. I'll probably run some type of Cobra replica 9 in wheel since they are available in 4 lug now. I also need to know of a 140 or higher tread wear rating tire to fit in the "stock" class.
Your comments and ideas are extremely appreciated.
93 mustang notch
budget .50 cents
