Hesitation Problem Help
  • Thread starter Thread starter foxconv
  • Start date Start date Feb 22, 2016
1 of 2 Next Last
F
foxconv
25
  • Feb 22, 2016
I own a 89 convertible Foxbody mustang. It runs good most days but sometomes its starts to have a really bad hesitation. It hesitates so bad that you can't drive it. Also it usually occurs around 2500 to 3000 rpm. When it hesitates, the rpm starts flickering like crazy and you can't accelerate past 3000rpm. Details about the car is that it is bone stock. 302HO. No check engine light. Just airbag light is on.
Boosted92LX
5,721
4,244
224
Feb 22, 2016
  • Feb 22, 2016
I'm not positive, but I don't think 89 cars had a check engine light, newer cars do.. Or was that 87???? You need to check for codes anyway, I'd say.
F
foxconv
25
  • Feb 22, 2016
I already checked for codes with a obd1 scanner and no codes came up. Only thing right now is that the airbag light keeps flashing.
A5literMan
At least it is lumpy...
5 Year Member
Jul 30, 2011
4,674
2,343
194
Illinois
Feb 22, 2016
  • Feb 22, 2016
No codes or a code 11? More than likely a sensor issue. But could be other things like ignition, gas,vacuum leak,etc. have you recently had any work done to the car? Also this should be in tech not talk?
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
Feb 22, 2016
  • Feb 22, 2016
No code 11 (two flashes when the computer dumps the codes)? A perfectly functioning system will always get a code 11, it is the everything is OK code. The 11 code is computer passed its internal self test.
If you don't get an 11, you have computer or wiring problems.
Please check and repost.
F
foxconv
25
  • Feb 22, 2016
Yeah I got a code 11.
F
foxconv
25
  • Feb 22, 2016
I just did the jumper method and it gave me that code.
A5literMan
5 Year Member
Jul 30, 2011
4,674
2,343
194
Illinois
Feb 22, 2016
  • Feb 22, 2016
Do you have good spark? What kind of condition are the wires,plugs,cap,rotor,and coil? I'd start there.
F
foxconv
25
  • Feb 22, 2016
I got a new distributor but old wires and spark plugs but they look in ok condition. Most the time the mustang runs fine but some days for no reason when I start it and try to go for a cruise, it starts hesitating really bad to the extend that you can't drive it. Then the next day I start it up and its all fine.
A5literMan
5 Year Member
Jul 30, 2011
4,674
2,343
194
Illinois
Feb 22, 2016
#10
  • Feb 22, 2016
  • #10
What brand of distributor?
@jrichker could this be the pip sensor?
jrichker
Mar 10, 2000
27,512
2,813
234
Dublin GA
Feb 22, 2016
#11
  • Feb 22, 2016
  • #11
Does the problem seem to appear only after the engine has warmed up?
Boosted92LX
5,721
4,244
224
Feb 22, 2016
#12
  • Feb 22, 2016
  • #12
TFI?
F
foxconv
25
#13
  • Feb 22, 2016
  • #13
I got a brand new distrubitor, tfi, pip. The hesitation occurs even if the car is cold. Can it be a bad fuel pump or regulator?
F
foxconv
25
#14
  • Feb 22, 2016
  • #14
Also realized there is some oil leaking out from the side where the heads meet the block. Bad gasket im assuming. That can't be the cause of the hesitation because if it was, it would occur all the time.
A5literMan
5 Year Member
Jul 30, 2011
4,674
2,343
194
Illinois
Feb 22, 2016
#15
  • Feb 22, 2016
  • #15
Put a gauge on the regulator and see what pressure you have. It could be the pump or regulator or filter or...?
mikestang63
SN Certified Technician
Aug 27, 2012
11,606
8,859
214
In the garage
Feb 22, 2016
#16
  • Feb 22, 2016
  • #16
didnt know 89 was an airbag car.
A5literMan
5 Year Member
Jul 30, 2011
4,674
2,343
194
Illinois
Feb 22, 2016
#17
  • Feb 22, 2016
  • #17
Mine wasn't
F
foxconv
25
#18
  • Feb 23, 2016
  • #18
Mine does. It has a later model looking steering wheel. Ill check again if its a 89.
F
foxconv
25
#19
  • Feb 23, 2016
  • #19
Oops it was a 91. Got it confused with my other mustang I sold. It shouldn't matter though.
mikestang63
Aug 27, 2012
11,606
8,859
214
In the garage
Feb 23, 2016
#20
  • Feb 23, 2016
  • #20
it actually does- of you had an airbag light going off in an 89 then someone had changed the harnesses and gauges,- 89 and 90 engine harnesses are different.
carry on
1 of 2 Next Last
Engine Rough idle and aggressive sputtering when accelerating
  • 88vertible
  • Aug 13, 2025
Fox 5.0 Mustang Tech Dec 13, 2025
Jarhead67
J
  • Gulftown980x
  • Jul 29, 2026
  • SN95 4.6L Mustang Tech
squeak93
M
Too much for me to repair in my current housing situation
  • My Drama Magnet 04 Gt
  • Apr 1, 2026
  • The Welcome Wagon
The Welcome Wagon Apr 14, 2026
Throttle cut out at 3500 rpm
  • Piranahbite
  • Jul 8, 2023
  • 2.3L (N/A & Turbo) Tech
4K
2.3L (N/A & Turbo) Tech Nov 9, 2023
AeroCoupe
Fuel Spits sputter pops and bangs under load. Help wanted
  • sickntired
  • Mar 23, 2024
4K
Fox 5.0 Mustang Tech Apr 1, 2024
sickntired
