Hesitation while accelerating
  • Thread starter Thread starter dynasty_365
  • Start date Start date Jun 16, 2011
First Prev 2 of 2
O
ohlang
Charlotte, NC
Feb 14, 2016
#21
  • Feb 14, 2016
  • #21
dynasty_365 said:
...it's really only in like 4th gear when I get on it wot.
There's nothing wrong with your car. The answer's been provided by some of the other members. I just found this out myself recently after getting a custom tune and although the tune itself did not remove the "problem", it was during testing the tune that the tuner told me to turn traction off, but he never outright told me that that was the cause of the lag. But having tested in with traction on and in Advancedtrac Sport Mode (I prefer to have some traction in place), the traction control is the culprit. Don't know if Advancedtrac Sport Mode or Track Mode is new and only available on 2015 and later models, but you should be able to turn off traction control to test it.
2012red
USA
Jun 5, 2018
#22
  • Jun 5, 2018
  • #22
I wanted to update this old thread because I was through this problem and didn't really find any conclusive explanations of a cure. I had a bad hesitation between 4000 and 5000 rpm. It would almost feel like in a weaker car when the air conditioning clutch kicks on. Car threw no codes or otherwise showed something was wrong. After around 5000 rpm it would take off again as if full power was restored.
Went to change the oil and realized it was way down on oil. During the change I came to do the filter and it was full of gummy, not new, oil spray on the outside. There was zero indication of this having happened under the car in the driveway, no dash light, etc. As it turns out the 500S filter had a failing oring seal. I suspect it was only blowing oil past the seal at high rpm when the pressures increased, but nonetheless the oil level was now embarrassingly low. Changing the filter and putting in the standard 8qts of new oil, the hesitation problem immediately ceased. I hadn't realized it during driving before the oil change, but afterwards I could tell the car was actually down on power almost across the whole rpm band, not just the hesitation previously described. I am unsure if the loss in power was related to the low oil level, or the fact that the seal was blowing and leaking purging oil pressure only at high rpm. Post-oil change though with the new filter, everything is back to normal.
So if you're having this hesitation problem, try changing the oil/filter. Certainly beats paying a diag fee if this ends up being your problem.
First Prev 2 of 2
Acceleration Vibration
  • Blown02svt
  • Dec 31, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jan 5, 2026
General karthief
D
66 Coupe Progress Thread
  • DTCRAWLEY
  • Apr 19, 2026
  • 2 3
1965 - 1973 Classic Mustangs -General/Talk- Jun 17, 2026
DTCRAWLEY
D
Suspension End link replacement size
  • Teen'93stang5.0
  • May 12, 2026
Fox 5.0 Mustang Tech May 20, 2026
Teen'93stang5.0
Engine Multiple o2 sensor codes, car runs terrible
  • 02newedge
  • Jun 12, 2025
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Jul 19, 2025
squeak93
Removing speedo cable from the VSS
  • 91AOD5.0LX
  • Mar 25, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Apr 25, 2026
91AOD5.0LX
