  • 1994 - 1995 Specific Tech
Hey Tom Moss
  • Thread starter Thread starter final5-0
  • Start date Start date Jan 14, 2006
final5-0
Mustang Master
Apr 6, 2003
6,817
12
79
DFW Texas
Jan 14, 2006
  • Jan 14, 2006
Hey Tom
Original poster in this thread says his intake has been gasket matched.
http://forums.stangnet.com/showthread.php?t=608121
Would you please give a comment or two on this subject.
Things like, how effective the procedure is.
Can it hurt more than help?
etc
From time to time, I've had mixed feelings about this
Grady
blksn955.o
3,263
st.louis mo 314
Jan 14, 2006
  • Jan 14, 2006
I am not Tmoss (preaty obvious), but I did get to watch him port my explorer lower...
What I got out of watching (it was a neato thing too, thaks a million Tmoss) was the restriction is at the tapper on the runners not the actual port opening. Most of the runners had a inside runner wall like this | / or like this \ | with 1 or 2 runners actually being \ / ( I want to say its #4 & 8 but it was the straightest runners that were the worse for this reason.
While watching him port it he had a drop light behind it and you could see the "cuts" straighten out the runners and remove this restriction.
again this is what I got out of it, and hopefully Tmoss will reply with more info as I realy like the topic.
tmoss
Gettin Wired
7,153
32
128
Saint Louis, MO
Jan 16, 2006
  • Jan 16, 2006
Port matching will rarely hurt, unless it's done poorly. How much gain you get depends on how much the combo needs the additional air flow. Also, there is porting an intake runner which includes re-shaping the runner in my book, but those who do it themselves may not go that far - so it is a VERY subjeective thing to say an intake was "port matched".
Zero Signal
2,633
Tucson, AZ
Jan 16, 2006
  • Jan 16, 2006
My definition of port matching is just aligning the port edges to eliminate the lip.
My definition of gasket matching is matching both ports to the gasket for the same reason.
In the case of the Explorer intake, the upper and lower aren't even aligned. So port matching via gasket (i.e. gasket matching) could definitely help.
But on the manifold-to-head ports, as long as the ports are aligned, I don't see a big benefit. Kind of like having a 3" pipe with water flowing through, then randomly throw in a section of 4" pipe. In theory it will only cause an energy loss.
I could see port matching them with a nice taper and only open where you need to, rather than matching a gasket thats a lot larger than both ports to begin with. Just my take on it. To keep from taking off more than you need, I would use that machinist spray die stuff. Then you mate the surfaces and see exactly where it needs it.
  • 68_Disgustang
  • Feb 22, 2026
1965 - 1973 Classic Mustangs -General/Talk- Oct 19, 2026
mattcrp1
M
Upgrade Advice on an 89 GT Convertible NJ
  • SteakDad
  • Apr 17, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Apr 18, 2025
limp
  • D Durden
  • Oct 20, 2025
  • 2 3
4K
SURGING IDLE / NO IDLE CHECKLIST FOR 1996–1998 MUSTANG GT (4.6L 2V) - Work In Progress
  • Noobz347
  • Aug 30, 2025
1996 - 2004 SN95 Mustang -General/Talk- Aug 30, 2025
For Sale 3-owner 1987 Mustang GT, $18K obro, Lancaster CA
  • Bill Cool
  • Oct 6, 2024
2K
Fox Body Mustangs For Sale (1979-93) Oct 13, 2024
nickyb
