Hi-Torque Starter Wiring Question
  • Thread starter Thread starter techsan
  • Start date Start date Mar 22, 2007
T
techsan
20
Houston
Mar 22, 2007
  • Mar 22, 2007
I recently bought a Hi-torque starter (p/n M11000-B51), which didn't have any wiring schematics with it . I downloaded a set of instructions that claimed to work for several different starters, including the 1.1 kW starter and the old Hi-torque starter (M11000-B50). I wired the starter according to the schematic with those instructions. The starter cable (thick wire) was run from the positive side of the starter relay (same side as the positive battery cable), to the 8mm stud on the starter solenoid. The second wire (12 guage skinny wire) was run from the other side of the relay to the 4mm stud on the solenoid.
I think that the wiring diagram was backwards because the loop on the thick wire doesn't go over the 8mm stud, and the loop on the skinny wire fits perfectly over the 8mm stud. I filed the hole on the thick wire, and after hooking it up according to the diagram, the starter spins, but doesn't kick over and engage the flywheel.
I think that i need to swap the wires on the starter, just wondering if anyone has any experience with this or knows why the starter wouldn't be kicking over. Any links to a correct schematic would also be appreciated
BK_CAULEY
it's built for speed not longevity, woman
Dec 26, 2006
49
Thomasville, ga
Mar 22, 2007
  • Mar 22, 2007
the wire from the solenoid to the starte should not be on the same pole as the positive to the battery. if it is the starter is going to engauge it should be on the opposite side so when the solenoid closes it can send power to the starter. and the skinny wire is the one that connects to the solenoid. it should wire up like a factory starter.
9
95GTAODE
200
  • Mar 22, 2007
You had it wired correct. (Big wire from + side of relay to big stud on starter, small wire from switched side of relay to small stud) I had to enlarge the hole on my factory cable to use the mini starter as well.
I would go through and ensure everything is tight, and the 2 wires aren't touching on the starter.
C
Electrical HELP! 1989 5.0 Stick, Voltage Bleed onto Ignition Trigger wire
  • ChickenDeluxe
  • May 14, 2026
Fox 5.0 Mustang Tech May 24, 2026
ChickenDeluxe
C
Motor craft starter wired same as mini starter?
  • Creomod
  • Aug 20, 2022
2K
Fox 5.0 Mustang Tech Aug 23, 2022
90sickfox
Starter, Solenoid, Clutch Safety Switch, OR??
  • 1992MustangGT
  • Dec 31, 2021
6K
Fox 5.0 Mustang Tech Jan 5, 2022
manicmechanic007
C
Engine No Crank Issue (But Starts When Jumping Big Terminals on the Starter Solenoid)
  • Cabernet88GT
  • Jun 6, 2021
7K
Fox 5.0 Mustang Tech Jun 6, 2021
Cabernet88GT
C
Electrical Battery Drain / slight draw
  • R82148V
  • Jun 2, 2022
3K
Fox 5.0 Mustang Tech Jun 2, 2022
Mustang5L5
