  • SN95 4.6L Mustang Tech
hid ballasts destroyed
  • Thread starter Thread starter 2000fordstanggt
  • Start date Start date May 20, 2008
2000fordstanggt
404
Westland, MI
May 20, 2008
  • May 20, 2008
why are some ballasts able to run directly off the headlight off the headlight harness and some aren't?
if you run your own power with a relay youre really turning on a relay with a relay from the fuse box.
how many amps does the ballast take for startup? if anyone knows..
check out my 5 month old fog light ballasts..
*pics coming in a couple hours* sorry
main question, i need ideas for mounting the ballasts, besides the inside of the actual bumper shock absorber with self tapping screws.
urban96
bubb rubb says:"woo woooooo"
3,464
Syracuse, NY
May 20, 2008
  • May 20, 2008
I would power them off the battery with a relay. I would not want to overload the OEM headlight wiring, its not too thick and im sure its pretty long meaning with excessive draw itll heat up
spend the $20 and get a wiring kit or make your own and then just tap into the oem wiring to switch on the relay
Mossberg
ATL, Shawty
May 20, 2008
  • May 20, 2008
I agree, this is always the safer bet.
Mustang5L5
Mod Dude
Feb 18, 2001
43,365
18,109
224
Massachusetts
May 20, 2008
  • May 20, 2008
That should all be run off the battery and the stock wiring simply used to trigger relays to switch them on. They draw a LOT of amps on startup and can cook the wiring or shorten the ballast light.
That's the difference between good HID PnP kits and cheap ones. The cheap ones don't offer a relay kit while the good ones usually do (or have it as an additional accessory purchase)
san~man
O-G
A little grass shack on a big lava rock
May 21, 2008
  • May 21, 2008
You should never run a high current draw accessory (like an HID ballast) off the factory wiring. That's simply a recipe for trouble.
Like the others have said, buy a ready made harness that will run straight to the battery with a relay, or make your own.
Electrical 1985 mustang gt Led conversion trouble
  • 1985fox
  • Jan 5, 2026
Fox 5.0 Mustang Tech Jan 15, 2026
1985fox
F
Electrical From scratch: alternator wiring
  • fox racer v2
  • Jun 23, 2025
Fox 5.0 Mustang Tech Jun 23, 2025
fox racer v2
F
1999 Mustang GT - No Start- Need help understanding the fuel pump circuit and how it works
  • 99gtGuy
  • Nov 4, 2025
1996 - 2004 SN95 Mustang -General/Talk- Nov 7, 2025
04newedge-
A
Resolved Fuel Pump issue - test port jumped comes on (87 LX)
  • afjLX
  • Nov 16, 2024
2K
Fox 5.0 Mustang Tech Nov 26, 2024
afjLX
A
V6 to V8 Swap info
  • 02_2v_Curtis
  • Jan 11, 2026
1996 - 2004 SN95 Mustang -General/Talk- Oct 7, 2026
2v_johnny
