  • SN95 4.6L Mustang Tech
Hid Problem...
  • Thread starter Thread starter jdmsi94
  • Start date Start date Aug 31, 2007
jdmsi94
DFW, TX
Aug 31, 2007
  • Aug 31, 2007
Anyone have hid's that had a problem installing them? All they do is flicker and go off. Sometimes they will come on, which tells me they work?
Please Help...
joshjwc9
1,095
17
39
Palm Harbor, FL
Aug 31, 2007
  • Aug 31, 2007
Sounds like you got a loose wire going from the ballast to the bulb.
Is it only one light that flashes and goes out or both?
jdmsi94
DFW, TX
Aug 31, 2007
  • Aug 31, 2007
it is a used kit I bought and I have only tried to install the driver side. I have heard alot of people using relays? Not sure how they work?
1992 2.3LX
885
Ky
Aug 31, 2007
  • Aug 31, 2007
it is a used kit
located your problem.
joshjwc9
1,095
17
39
Palm Harbor, FL
Sep 1, 2007
  • Sep 1, 2007
And you only have one light that has the HID bulb?
There might be an electrical issue because without two ballasts their is a different draw from each bulb too.
trinity_gt
3,125
81
99
Canada
Sep 1, 2007
  • Sep 1, 2007
Either a bad wiring connection or a fault in the ballast (like a bad solder joint, for instance...)
Have you tried lightly tapping the ballast when the HID is on to see if vibration has something to do with it?
twogts4us
4,188
12
79
Dunedin, FL
Sep 1, 2007
  • Sep 1, 2007
Wear a condom
Oh, you said HID...sorry
:OT:
screamin gt
5 Year Member
Apr 9, 2007
393
central CT
Sep 2, 2007
  • Sep 2, 2007
try what he said. I had the same problem with one I had on my bike. had to swap out the ballast.
I also had a problem (seperate issue) with one where it would light up fine, and then go out while riding. I secured the ballast so it wasn't jiggling around and that solved that issue.
one thing I've realized about hid's is they are very fragile. and it seems as though for what you pay for them, the ballasts should be made much more durable.
even so I am still thinking about getting another set for my car.
Installed xm radio shaker 1000
  • Rollback82
  • Jun 14, 2026
2005 - 2014 S-197 Mustang -General/Talk- Jun 14, 2026
08shelby GT500
T
Inside is completely dead
  • TunaCar
  • Oct 18, 2026
SN95 4.6L Mustang Tech Oct 20, 2026
DadLife0724
K
Electrical 2000 GT Intermittent Engine Shutdown In Motion - DTC U1262
  • kenster1092
  • Apr 13, 2026
SN95 4.6L Mustang Tech Apr 24, 2026
squeak93
2003-04 Mustang Cobra Brake Conversion
  • Cassiebaebae
  • Oct 8, 2026
1996 - 2004 SN95 Mustang -General/Talk- Oct 24, 2026
Bib36`
2010 V6 Sees differently than GT?
  • 6t9Mach1
  • Mar 31, 2026
  • 2010 - 2014 Specific Tech
2010 - 2014 Specific Tech Apr 1, 2026
6t9Mach1
