Hide wires
  • Thread starter Thread starter baldy1
  • Start date Start date Sep 13, 2007
baldy1
124
Portsmouth Va
Sep 13, 2007
  • Sep 13, 2007
Can someone point me the right direction. I have heard and seen people hide thier wires in side fender wells and such is there an old thread on this and the how to.
Thanks
89Notch
1,669
MSU
Sep 13, 2007
  • Sep 13, 2007
yes
4G-KDMP
935
CA
Sep 13, 2007
  • Sep 13, 2007
89Notch said:
yes
you're not suggesting doing a search are you?
Flavadave4
1,044
21
49
Utica, NY
Sep 14, 2007
  • Sep 14, 2007
Mansonozz has a write up about hiding wires on his site.....here is the link.
http://www.soniccherry.com/wires.html
MarcMonteverde
66
S@c-ToWn
Sep 14, 2007
  • Sep 14, 2007
i moved all my wires to the inter fenderwell, theres a little hole like maybe 2 1/2 inchs wide right behide right to the driver side strut, if u put ur hand on the strut, go towards the brake booster, and go down you'll feel the hole, i moved all my wires into it , the starter rely, all the annoying wires the only thing on that side of the car is the coil, i moved the battery to the trunk as well, i made a big differents
looks good
ALMOST STOCK
1,250
41
88
CA.
Sep 16, 2007
  • Sep 16, 2007
This might be helpful also.
http://www.leemotorsports.com/almoststock/
baldy1
124
Portsmouth Va
Sep 16, 2007
  • Sep 16, 2007
So I dont have to make any wires longer. Besides the battery cables.
88mouse
630
Mooresville nc
Sep 16, 2007
  • Sep 16, 2007
Nope. I just got done doing the same thing. But i moved my battery to the truck. You will have to mover part of the headlight harness to the inner fender also. You can also move the harness on the pass. side to the inner fender as well. I also pulled my dash out and ran the harness inside the car, cut a hole in the middle of the firewall so that there is only there plugins in the engine bay.
04sleeper
2,674
14
89
Dallas, TX
Sep 16, 2007
  • Sep 16, 2007
Every time I see Paul's engine I just
baldy1
124
Portsmouth Va
Sep 17, 2007
#10
  • Sep 17, 2007
  • #10
Thanks for everyones help. I am in the middle of tearing my car apart and doing alot of changes to it. Trans, motor and wiring. Body work and interior. Got some pics. As soon as I get my site done I will post a link. Again thanks for your help.
Flavadave4
1,044
21
49
Utica, NY
Sep 17, 2007
#11
  • Sep 17, 2007
  • #11
Be sure to post some pics!
G
Resolved Smoking Wiring Issue After GT40 Head Swap
  • Grapes
  • Aug 15, 2026
Fox 5.0 Mustang Tech Aug 22, 2026
Grapes
G
Electrical Ron Francis Headlight / Alternator Harness
  • dan50
  • Apr 30, 2026
Fox 5.0 Mustang Tech Apr 30, 2026
dan50
C
Electrical HELP! 1989 5.0 Stick, Voltage Bleed onto Ignition Trigger wire
  • ChickenDeluxe
  • May 14, 2026
Fox 5.0 Mustang Tech May 24, 2026
ChickenDeluxe
C
W
Engine My engine dies after running 10 to 15 minutes under high heat.
  • Wylieone
  • Jun 21, 2026
Fox 5.0 Mustang Tech Jun 22, 2026
Mustang5L5
Electrical 91 hatch wiring help needed
  • FastDriver
  • Apr 7, 2026
Fox 5.0 Mustang Tech Apr 8, 2026
FastDriver
