I've had a high idle problem for a while. I'll be sitting at a stop sign or light and the engine will rev up and stick. I'll be pushing around 2500-3000 rpms. While I'm shifting, same thing. I replaced the throttle body and EGR plate and it still did it.
Yesterday I went to Kragen and ran it on the code machine. It came up with 2 codes: 33 and 4. I looked up 33 and it said it was the EGR Valve. I replaced that today and it was fine for a few test drives. Then it came back.
Not as bad as before but it is still there. I'm going to replace the vacuum line to the EGR Valve tommorow and see if that does the trick. Anyone have another idea? Also, what is code 4?
),I think the "4" you got might have just been the ingine ID bleeps you get when running the codes..I want to remember that 4 is for a V8 and 2 is for a 4cyl....I could be way off on that though...
