  • SN95 4.6L Mustang Tech
high idle problem
  • Thread starter Thread starter cobrajeff00
  • Start date Start date May 1, 2006
C
cobrajeff00
12
  • May 1, 2006
My 00 idles high and sloooowly comes down to 800rpm if you wait long enough (10-15 seconds). This is real annoying and sounds awful. I cant rap the throttle and when you pull up to a light, it just hangs around 1200 rpm mark, then gradualy makes its way down to 800, unless the a/c compressor kicks in, then it holds at the 1200 range. I have a friend with a 97 gt with the same problem. any ideas ?
Warrior 102
231
Macomb MI
May 1, 2006
  • May 1, 2006
search for Fix your Slow dropping/hanging RPMs........
jstreet0204
939
Winston Salem, NC
May 1, 2006
  • May 1, 2006
Try tapping the IAC valve with a metal wrench. This is usually caused by the IAC sticking. Tapping it will often knock it loose and solve the problem. DO NOT take the advice in the post provided by the previous poster. Those post will tell you to place a restriction in the path of the IAC. If you are already having idle problems, that only stands to complicate them. If you have no idle problems then the restriction works ok to help speed up the dashpot rate.
mity2
I like Pro3 and all I got was this crappy CT.
Jul 24, 2003
2,872
StateCollege PA
May 1, 2006
  • May 1, 2006
make sure your PCV(rubber O-ring where PCV is connected to) is not leaking vacuum.
stroked4.6
39
New York
May 1, 2006
  • May 1, 2006
You should clean your IAC but this is only a temporary fix. If you idle does improve then you know you need to buy a new IAC valve. You can use Carb cleaner to do this.
K
Engine 2000 Mustang GT - Fuel issue post-blown spark plug repair
  • kenster1092
  • Feb 26, 2026
SN95 4.6L Mustang Tech Mar 10, 2026
kenster1092
K
Engine Surging idle on start-up
  • keel
  • Aug 11, 2025
Fox 5.0 Mustang Tech Oct 31, 2025
keel
SURGING IDLE / NO IDLE CHECKLIST FOR 1996–1998 MUSTANG GT (4.6L 2V) - Work In Progress
  • Noobz347
  • Aug 30, 2025
1996 - 2004 SN95 Mustang -General/Talk- Aug 30, 2025
H
Hanging idle issues
  • HydraX
  • Mar 22, 2025
  • SVT Tech Forum
SVT Tech Forum Aug 4, 2025
squeak93
SURGING IDLE / NO IDLE CHECKLIST FOR 1999–2004 MUSTANG GT (4.6L 2V) - Work In Progress
  • Noobz347
  • Aug 30, 2025
