The coolant temperature sending unit (not "sensor") is on the driver side of the intake manifold, and it's screwed directly into the manifold. (The ECT sensor is screwed into the heater core feed pipe which is then screwed into the manifold.) It has a single-wire lead that is pushed onto the stud coming out of the top if the sending unit.
http://www.allfordmustangs.com/foru...temperature-sensor-act-my-new-car-015-act.jpg
this sensor tells the computer the motor is cold. therefore acting like a choke it gives the motor more fuel to warm up faster and run right when u dont let it warm up properly. just like a carburated motor with a choke. usually when they go out its a reverse effect when its saying its hot its cold and when its cold its hot. seen it thousand of time especially on 80 model chevy. not saying that ur problem but may be. usually cleaning wont help.
