  • 1994 - 1995 Specific Tech
High RPM Cutout
  • Thread starter Thread starter DFG 5OH
  • Start date Start date Sep 12, 2005
First Prev 2 of 2
W
walker95svt
69
Abilene, TX
Sep 13, 2005
#21
  • Sep 13, 2005
  • #21
valve float
valve float can most certainly make a car fall flat on it's face, much like a rev limiter. Do you have stock springs with a gigantic cam? old springs? I think it's possible.........but others think I don't know what the hell I'm talking about
bimmertech
1,123
merriam, ks
Sep 13, 2005
#22
  • Sep 13, 2005
  • #22
a50sn95 said:
If they are the out of the box plugs for our cars, then they are .045 or .050, which will be too much on a boosted car. Definitly my guess for your car.
Also the platinum plugs are not recommended for boosted vehicles. I looked up why once, but forget. Something about not being able to take the extra heat and actually melting off the plug and the bits could damage other parts...
platinum plugs retain a fair amount of heat which can cause pre-ignition.
as far as the original thread problem goes, i would venture a guess at a fuel pump.
DFG 5OH
1,341
Louisville, KY
Sep 13, 2005
#23
  • Sep 13, 2005
  • #23
the engine is 100% stock
a50sn95
368
Elk Grove, CA
Sep 13, 2005
#24
  • Sep 13, 2005
  • #24
My guess is ignition. When was the last time the Primary ignition system was replaced?
Cap, Rotor, wires, plugs......
Dennis
DFG 5OH
1,341
Louisville, KY
Sep 13, 2005
#25
  • Sep 13, 2005
  • #25
Dennis
less than a year ago, all are fresh
CManT1914
3,172
Killeen, Texas
Sep 14, 2005
#26
  • Sep 14, 2005
  • #26
I'm still saying it's ignition related, more specifically the coil. Anybody want to put money on it?
95WhiteVenom
624
Alabama
Sep 14, 2005
#27
  • Sep 14, 2005
  • #27
well chris seeings how i have had the same problem ill take some odds, chris i bet you a case (bud light) its the coil.
W
wytstang
Mustang Master
Mar 14, 2004
4,988
Summerville,SC missing South Fl. weather :(
Sep 14, 2005
#28
  • Sep 14, 2005
  • #28
Wires.........
DFG 5OH
1,341
Louisville, KY
Sep 14, 2005
#29
  • Sep 14, 2005
  • #29
But could the coil and wires make my car so down on power, cut out in the high RPM's and rev slow...ect? Is there a way to test it?
CManT1914
3,172
Killeen, Texas
Sep 14, 2005
#30
  • Sep 14, 2005
  • #30
How about I bet YOU that it's the coil. Too bad I can't actually buy beer, lol.
Teh coil could definitely do this, I would think that for the wires to be the problem, EVERY single one of them would have to be bad, and I don't think that's as likely as the coil. Sorry, I don't know of any way to test it though.
DFG 5OH
1,341
Louisville, KY
Sep 14, 2005
#31
  • Sep 14, 2005
  • #31
well tonight i'm going to do a compression test, and test the voltage coming off the MAF. Hopefully i can either rule them out, or find my problem. Anyone got a stock coil
CManT1914
3,172
Killeen, Texas
Sep 14, 2005
#32
  • Sep 14, 2005
  • #32
Yep, but it's bad.
DFG 5OH
1,341
Louisville, KY
Sep 14, 2005
#33
  • Sep 14, 2005
  • #33
CManT1914 said:
Yep, but it's bad.
damn
First Prev 2 of 2
J
Reduced power in 1st and 2nd gear
  • jimted79
  • Feb 25, 2025
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Feb 25, 2025
studder/miss on 289 on hard(er) acceleration
  • Bristang5
  • Sep 18, 2024
1965 - 1973 Classic Mustangs -General/Talk- Oct 19, 2024
jonbearman
J
Drivetrain 83’ Glx convertible C5 Trans help!
  • JacksonJared2113
  • Dec 25, 2025
Fox 5.0 Mustang Tech Dec 26, 2025
JacksonJared2113
P
High idle issue and leaking after running.
  • PHoffman
  • Dec 24, 2024
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Dec 24, 2024
General karthief
Engine Rough idle and aggressive sputtering when accelerating
  • 88vertible
  • Aug 13, 2025
Fox 5.0 Mustang Tech Dec 13, 2025
Jarhead67
J
