I don't believe the possible internet myth that boost on a small displacement motor makes bigger than normal and/or short runner intakes like the TFS-R w/ box, the spider, victor, or Hurricane more preferable. I'd like to see any documentation or logic explaining why boosted motors of a given displacement will see better results with high flow/high rpm intakes than their non-boosted counterparts.
All boost does is compress and heat air. The volume of air moved in a given amount of time is still identical to the non-boosted motor. The only argument that even seems viable to me is that air velocity is reaches the sonic threshold when compressed and doesn't when not compressed because the threshold may be lower with compressed or heated air. I'm not sure that this is the case, and would need details to support this.
I might be wrong, but from what I understand about boost is that it makes the intake a non-factor. In other words, generally speaking, a long runner intake will act exactly the same as a short runner intake when they are set up identically and boosted identically. Same is supposed to be true for plenum volume, and to a lesser extent the port size. However, port size can be too big or too small on a boosted engine.
That is why I say 'generally' speaking intake specs are a non-factor when boosting.
That's my .02 and the way I understand it.
My .02 is worth exactly what you paid for it!
but for the record, Richard Holdener has written some interesting articles over the years dyno testing every kind of combo imaginable... and his general philosophy is that you match your H/C/I combo, and the boost just multiplies the power. He tends to like long runner intakes (like the Holley Systemax) on all but the most radical builds.
I couldn't get the car to run any better than 11.70-80s. Then my friend told me to quit driving like a wuss and let her eat. We trailered the car to the track and we were already building a new engine, so I said screw it. I think the spark cut was set to 6400 rpms and the fuel cut was set to 6500 rpms so I tried to rev it close to 6500 on the shifts. The car responded with an 11.36 @ 122. Ran .40 quicker in the quarter by using an extra ~500rpms. Mind you, this was over 1000rpms more than my best pass N/A.
