Engine High Rpm Miss/powerloss?
dbenedict2012
Missouri
Hello All,
87 LX 5.0
306 fully balanced
BBK fuel pump
BBK adjustable fuel pressure regulator
19lb Ford Injectors
Cobra upper and lower intake-ported & polished
Ford Racing E303 cam
Truck E7 heads ported and polished
1.7 roller rockers
MSD cap & rotor
BWD performance ICM
Ford Racing Wires
Rotorcraft Copper plugs gap 0.44
CAI
I'll describe my problem and then follow up with what all I have done to my car.
When accelerating hard above 3000rpm my engine will act like it misses. It feels like a power loss, as if it wasn't getting fuel. Once it drops to lower rpms it stops completely.
I initially thought it was a fuel issue. I checked my fuel and my pump was putting out 40lbs of pressure. But my regulator was not working properly. So I replaced with BBK 1706 adjustable fuel pressure regulator.
After that...thought spark..replaced plugs with with motorcraft listed above.
I'm now unsure as to what the issue is...do I need bigger injectors? Is my PCM not making the necessary adjustments at those rpms because of the camshaft?
Can anyone help?
It is usually either a TFI module or PIP sensor; dump the codes and see what comes up.
Dump the codes: Codes may be present even if the Check Engine Light (CEL) isn't on.
Dumping the computer diagnostic codes on 86-95 Mustangs
Revised 26-July-2011. Added need to make sure the clutch is pressed when dumping codes.
Codes may be present even if the check engine light hasn’t come on, so be sure to check for them.
Here's the way to dump the computer codes with only a jumper wire or paper clip and the check engine light, or test light or voltmeter. I’ve used it for years, and it works great. You watch the flashing test lamp or Check Engine Light and count the flashes.
Post the codes you get and I will post 86-93 model 5.0 Mustang specific code definitions and fixes. I do not have a complete listing for 94-95 model 5.0 Mustangs at this time.
Be sure to turn off the A/C, and put the transmission in neutral when dumping the codes. On a manual transmission car, be sure to press the clutch to the floor.
Fail to do this and you will generate a code 67 and not be able to dump the Engine Running codes.
attachment.php
attachment.php
What to expect:
You should get a code 11 (two single flashes in succession). This says that the computer's internal workings are OK, and that the wiring to put the computer into diagnostic mode is good. No code 11 and you have some wiring problems. This is crucial: the same wire that provides the ground to dump the codes provides signal ground for the TPS, EGR, ACT and Map/Baro sensors. If it fails, you will have poor performance, economy and driveablity problems
Some codes have different answers if the engine is running from the answers that it has when the engine isn't running. It helps a lot to know if you had the engine running when you ran the test.
Dumping the Engine Running codes: The procedure is the same, you start the engine with the test jumper in place. Be sure the A/C is off, and clutch (if present) is pressed to the floor, and the transmission is in neutral. You'll get an 11, then a 4 and the engine will speed up to do the EGR test. After the engine speed decreases back to idle, it will dump the engine running codes.
Your 86-88 5.0 won't have a working Check Engine Light, so you'll need a test light.
See AutoZone Part Number: 25886 , $10
Alternate methods:
For those who are intimidated by all the wires & connections, see Actron® for what a typical hand scanner looks like. Normal retail price is about $30 or so at AutoZone or Wal-Mart.
Or for a nicer scanner see Equus Digital Ford Code Reader (3145) Equus - Digital Ford Code Reader 3145.
It has a 3 digit LCD display so that you don’t have to count flashes or beeps.. Cost is $22-$36.
The TFI module mounted on the distributor is usually the culprit for a high speed miss on a warm engine. If the problem does not occur when the engine is cold, the TFI module is definitely suspect. You may need a special socket to remove the TFI module, but most auto parts stores will have one for $5-$7.
Be sure to use plenty of the heat sink grease on the new TFI and clean the old grease off the distributor.
See Automotive Tools Specialty | Auto Mechanic & Technician Diagnostic, Testing Equipment | Thexton
diagram courtesy of Tmoss & Stang&2Birds
"The TFI module mounted on the distributor is usually the culprit for a high speed miss on a warm engine. If the problem does not occur when the engine is cold, the TFI module is definitely suspect. "
This sounds a lot like my problem. I'll dump the codes tonight and see what happens.
