EMW150 said:You're missing the point I was making. Let's say you have a high volume oil pump. Relief spring at 60 psi like you said. Depending on the rpms, it's going to send X amount of oil somewhere. Lets say it's sending 500 CCs per minute (just pulled out of the sky) So let's say the relief valve will only flow 50 CCs and the engine load will only take 200 CCs to maintain 60 psi oil pressure. You got 250 CCs that won't relief because the relief valve is already flowing a full 50 CCs because the valve is fully open. The only thing that can happen is the pressure will spike and the oil will go to the source of least resistance. The source of least resistance is the top end... to the rockers. The numbers I used are for example only, but do you get my point?
Yeah... I get your point. Your theoretical oil pump is a MONSTER! lol
No really, I DO get what you're saying. Provided that the oil pump was a positive displacement pump and the path of least resistance was the top of the motor (this is assuming that the check valve is maxed out) then the pressure would rise until the capacity of the pump could no longer overtake the back pressure or supply any additional volume at whatever pressure it peaked at.
The thought that comes to mind though is first, (like I said above) that's one hell of a pump. We're talking about a pump that would seem to have been designed to pump more oil than our theoretic engine would ever have need for. Maybe a big block pump in a small block motor. Something else that comes to mind in this scenario is that this overly large pump is using horsepower that would be better spent at the flywheel. The last thing, is that if you're supplying those kinds of severely elevated pressures and volume that you're also running the risk of breaking the oil pump shaft or spinning or stripping the gears.
From what I've read, high volume, stock pressure pumps are designed to provide between 10% and 20% more volume than the stock piece. Assuming that some of that volume is consumed by the oil paths (I'll assume half) and some consumed by fighting against whatever rise in pressure you DO see then the rest would be your net result in higher pressure reading. If normal pressure for a combination is 60 psi at operating temp and 4000 RPM and you're seeing 80 or more then I'd say the pump was too big for the application. That's HP out the window. Not to mention wear and tear on the rotating parts. On more than one occation, I've seen reference to NASCAR oil pressures hovering about 40 psi all day long.
I'm sort of lost as to how this part of the discussion ended up so detailed. Granted that a higher volume oil pump would produce some pressure elevation so long as the capacity of the motor to make a path for that oil got closer to reaching capacity but it's also that very capacity limit that would keep the pump from feeding the motor to the point where the pickup ran dry. See what I'm saying?
