highbeams inop
tf85mustangGT
I have two 85 GT'S both have the same problem at night when i go to highbeams my head lights go off completly but as soon as i go to low beam lights they come back on it can take from 5min to 15min for it to happen. was told it is the switch but witch one headlight switch or the highbeam switch.
The headlight switch itself is what causes the issue in the '87-'93 cars. I'm going to assume you have the same thing going on. My old '89 did the exact same thing; new headlight switch fixed the problem.
I'd look for a bad MF switch. The headlight switch sends power to the MF switch and the MF switch divvies it up for lows or highs, depending upon where you position the turn signal stalk.
Good luck.
