highest stall for stock cam?
  • Thread starter Thread starter ninety1gt
  • Start date Start date Oct 26, 2005
ninety1gt
162
san antonio
Oct 26, 2005
  • Oct 26, 2005
whats the highest stall converter i can have with stock cam?? fyi an e303 mite go in later on.
L
luckythirteen13
648
Anaheim, CA
Oct 26, 2005
  • Oct 26, 2005
3000 is an all around good stall speed
aleborjas
610
  • Oct 27, 2005
1990LXDropTop
430
Western Massachusetts
Oct 27, 2005
  • Oct 27, 2005
I had a 2800 stall in my old GT with the stock cam. It worked very well.
brian15
81
  • Oct 27, 2005
my converter flashes around 3500 and i leave off idle back with all stock stuff i was going 1.78 60ft
with a stock cam but betters heads and intake i was going low low 1.7's
and with a lil spray high 1.5;s
worked well for me
Michael Yount
Mustang Master
Apr 10, 2002
9,039
Charlotte, NC
Oct 27, 2005
  • Oct 27, 2005
The issue isn't how HIGH the stall can be with a particular cam --- people setting the stall too LOW for a particular cam is usually the problem. Also how you're using the car is a significant issue.
If an E might go in later, size the stall for the E. The stock cam will be just fine with a higher than stock stall. And if you're trying to optimize your acceleration times, I wouldn't go any lower than 2500-3000 for the E. If you cruise in the car or use it significantly on the street, there are some things to consider. If your stall speed is above your highway or cruising rpms (a 3000 will be), it means you'll be running with some constant slip in the converter which = heat --- so an aftermarket tranny cooler is probably a good idea.
My suggestion? Lose the automatic and stick a manual in there.
D
davs5.0
921
windsor,ontario,canada
Oct 27, 2005
  • Oct 27, 2005
Give www.edgeracingconverters.com a good look. I and a bunch of others on here have them and they work great and their customer service is fantastic. I'd seriously look into a 3000 9.5" stall. Gets into the revs quicker due to its smaller diameter and lighter weight.
A good trans cooler is ALWAYS a good idea with an aod. Heat of any kind will shorten their life.
$uperstang
476
Detroit, MI
Oct 27, 2005
  • Oct 27, 2005
Give Edge racing a call and buy one from them you will be very HAPPY you did! Ask for Andre
J
Engine Stalling
  • josh40tay
  • Tuesday at 2:42 PM
Fox 5.0 Mustang Tech Wednesday at 7:18 PM
JD1964
Surging/stalling! problem or tune?
  • djj62478
  • Oct 4, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 14, 2026
KRUISR
J
Transmission
  • Jraesims
  • Mar 7, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Mar 8, 2026
JD1964
N
Engine 86 GT no start/stall
  • nweber
  • Jul 28, 2026
Fox 5.0 Mustang Tech Jul 29, 2026
AeroCoupe
Ford truck engine swap issues
  • keel
  • Jul 7, 2026
  • Other Auto Tech
Other Auto Tech Jul 13, 2026
General karthief
