Hiss after engine shutoff?
i saw my name and had to come in. i would agree with above. when the motor is off, there should be no vacuum, so no leak.....
ok, i gotcha. in the winter (no a/c) i have heard the same thing. for me, it sounded like it came from the pass front (near the charcoal cannister). i asked a bud and he said it is normal (coolant or something). to me, it sounded just like a drop of oil hitting the exhaust). i never could pin point the source (even with a stethoscope).
i think Mike (Mustang 5L5 has posted that it is normal too).
good luck.
Its ur engine gasping after you turn the car off. It needs more air!! Quick run out and buy more parts so it will get more air!!! I tried telling that to the wife but she didnt buy it... therefore still stock :(
you guys sure its not the fuel lines releasing pressure back to the tank? i know that the fuel pump is supposed to stay on for a few seconds after you shut the car off and that could be the noise. i know when my fuel pump relay went bad and my pump wasnt shutting off you could hear a hissing coming from under the hood and after a quick inspection it was coming from the fuel line
dude its normal I read your sig. and saw your mods. You have a fenderwell intake which means its no restriction, my stock intake on my notch did that but not very noticably, your aftermarket intake is no restriction just a tube with the mass air meter and a filter its normal. Its your intake depressurizing, it should only last for a matter of a split second or so after the car is off, depending on how hard you just drove it but don't worry it shouldnt be a problem.
When I plugged up the tube that goes from the valve cover to the TB I was getting a hissing. it was because the intake was sucking air from the PCV and there was no other place for it to get air, so it got it from the dipstick, which made a hissing after I shut the car off. I fixed that problem now :)
How did you fix that problem?
Mine hisses too, it might have been the PCV because i easily removed it, and put it back in the rear of the intake nice and snug. I thought it was a vac leak, havn't started it for a while but ill find out in a couple weeks!
If the valve cover hose is taken off, and plugged it will create vacuum in the crankcase and will grab air from any place it can. In my case it was from the dipstick. I put on a breather because when i hit boost it owuld pressurize my crankcase which I didn't want. this is just a temp fix, i am going to make a catch can for the pcv so I can put it on the inlet of my blower and not get oil inside it
