Quick question and let me know what you think. With the hood open, engine idling, and standing by the drivers wheel i can hear the carb making a hissing/sucking sound. It has been this way since the rebuild 4 months ago and cannot figure it out. Is this normal or abnormal?
Background: 1970 351w standard bore, stock heads (new valve job, guides, and hardened seats), Edelbrock 600cfm manual choke carb, Typhoon polished aluminum dual plane intake, stock flow mechanical fuel pump, and the following CompCams items: XE262H cam w/lifters, true dual roller timing chain, standard length pushrods, stamped rockers, slightly stiffer than stock springs per their recommendation, retainers w/10° keepers, and the adjustable valvetrain kit they sell for non-adjustable heads (basically a spacer and a tighter fitting nut).
The carb was completely rebuilt by me when it was found that the motor would not idle under 1500rpms. It turned out to be an internal vac leak in the carb.
I've sprayed carb cleaner everywhere till i'm blue in the face and have found no apparent leaks. Even replaced the intake gasket and used Grey RTV silicone instead of the end corks. Engine is rough idling for the first minute or so and i constantly have to tap the gas to keep it from dying. Vacuum guage bounces everywhere when cold, but once it is able to idle fine i am getting a steady 15 in Hg but still have the hissing sound.
If i were to have a vac leak or improper valvetrain adjustment, wouldn't this show up with the vac guage? Why is it bouncing like crazy for the first few minutes? Finally, could it be my air/fuel mixture? I don't have a wideband air/fuel meter, but have tried everything from 1.5 turns to 3 and i still get the hissing sound. I've even disconnected and put a pipe plug in the vacuum port in the intake to eliminate any external sources. Could my carb be too small? It doesn't backfire at all and the timing is set at 16° initial w/20° centrifugal for 36° total.
So, any ideas besides pulling my hair out? Probably something elementary that i'm overlooking.
Guess it wasn't a quick question after all
Thanks in advance!!!!
The best i can describe the sound is someone sucking through a straw.
Thanks in advance!!!!The best i can describe the sound is someone sucking through a straw.
amnit:
