hlow much for an entire clutch job?
depends on which parts. I went with the king cobra kit about $175 also your gonna need a new pilot bearing about $15. I would recommend an adjustable cable setup pending on who you go with $100-150 if you don't already have one.
nope, pilot bearing goes into the end of thr crank, trans input shaft rides on it, throwout bearing rides on the input shaft, contacts the clutch fingers by way of the fork to disengage the clutch when the pedal is pushed in,.good luck man
