I am running a Holley 4160 (650 cfm) on a '70 302 in a '67 convertible.
Specs:
stock 351W heads
Comp Cam roller tip rockers
Sig Erson cam: .447 lift, 222 degree duration
stock exhaust manifolds (headers as soon as I can afford them)
Aftermarket dual exhaust, with H-pipe, and Flow Masters
Weiand Stealth intake
Mallory Unilite conversion electronic ignition of stock distributor
My problem is that I am getting a too rich condition when stomping on the gas--lots of black smoke. Obviously it is an acceleratory pump problem, but the carb only has a 30 cc pump, with .025 accelerator pump nozzles (the smallest available). I am thinking of playing with the pump cams, currently using a yellow cam, but not sure if this will help.
Any Holley guru's out there with suggestions?
Thanks.
Specs:
stock 351W heads
Thanks.
