Looking For Some Advice....
I have a '94 GT 5 spd with a few mods and I am having a couple really nerve-racking issues that I hope I can explain clearly enough to have some light shed on by my fellow stangnetters...
'94 GT (Caroline)
'89 GT motor - new rings, new bearings, new HV oil pump & pick up, new timing set, ARP head bolts...
GT40 3-bar heads
CraneCams F3ZE 1.7 roller rockers
B-303
ProComp upper & lower intakes
Edelbrock intake adapter elbow
stock TB
Cold Air Intake (fenderwell pick up)
BBK Equal-Length shorty headers
BBK X-pipe
40 series Flows w/ turndowns
Steeda Progressive Rate Lowering Springs
All new shocks, struts, bushings, ball joints, etc...
18"x9"/18"x10.5" FR500 wheels (245/45/18 Front & 285/45/18 Rear)
3.73 gears
I rebuilt the motor myself and she runs like a top. I bought Caroline with her stock engine in fine working order; I had built this new engine for my Mark VII LSC. She runs great, but anywhere under 1800rpm, she chugs so badly and starts to buck. I immediately have to downshift to bring the rpm up to what she likes and then she runs great.
I don't understand why with the B cam and the 3.73's she runs like this... Is there too much duration for the gear or too much gear for the lift? Is the engine pulling in too much air with the CAI, larger intakes, and GT40's that the stock 19# injectors aren't supplying enough fuel? IS it a combination of the two?
This engine has always done this in this car. Last week I started running only NON-ethanol fuel and while it seemed to make her run considerably better, she still chugs...
The other problem I am having is when driving, either accelerating or maintaining speed, you hear this bub...bub..bub...........buh-bub...through the exhaust and you can feel it, almost like a miss... I have new '93 cobra spark plugs (to match the GT40 head/plug specs), maybe it's the wires? Or maybe the coil isn't as strong as the engine needs, just like the injectors...?
Help!!! Please let me know what you think. I am trying to narrow down my next move... This feels like a game of chess...
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,513
2,854
234
Dublin GA
It's not about just chances, it is about doing the diagnostic work....
Dump the codes: Codes may be present even if the Check Engine Light (CEL) isn't on.
Dumping the computer diagnostic codes on 86-95 Mustangs
Revised 26-July-2011. Added need to make sure the clutch is pressed when dumping codes.
Codes may be present even if the check engine light hasn’t come on, so be sure to check for them.
Here's the way to dump the computer codes with only a jumper wire or paper clip and the check engine light, or test light or voltmeter. I’ve used it for years, and it works great. You watch the flashing test lamp or Check Engine Light and count the flashes.
Post the codes you get and I will post 86-93 model 5.0 Mustang specific code definitions and fixes. I do not have a complete listing for 94-95 model 5.0 Mustangs at this time.
Be sure to turn off the A/C, and put the transmission in neutral when dumping the codes. On a manual transmission car, be sure to press the clutch to the floor.
Fail to do this and you will generate a code 67 and not be able to dump the Engine Running codes.
attachment.php
attachment.php
What to expect:
You should get a code 11 (two single flashes in succession). This says that the computer's internal workings are OK, and that the wiring to put the computer into diagnostic mode is good. No code 11 and you have some wiring problems. This is crucial: the same wire that provides the ground to dump the codes provides signal ground for the TPS, EGR, ACT and Map/Baro sensors. If it fails, you will have poor performance, economy and driveablity problems
Some codes have different answers if the engine is running from the answers that it has when the engine isn't running. It helps a lot to know if you had the engine running when you ran the test.
Dumping the Engine Running codes: The procedure is the same, you start the engine with the test jumper in place. Be sure the A/C is off, and clutch (if present) is pressed to the floor, and the transmission is in neutral. You'll get an 11, then a 4 and the engine will speed up to do the EGR test. After the engine speed decreases back to idle, it will dump the engine running codes.
Your 86-88 5.0 won't have a working Check Engine Light, so you'll need a test light.
See AutoZone Part Number: 25886 , $10
Alternate methods:
For those who are intimidated by all the wires & connections, see Actron® for what a typical hand scanner looks like. Normal retail price is about $30 or so at AutoZone or Wal-Mart.
Or for a nicer scanner see www.midwayautosupply.com/Equus-Digital-Ford-Code-Reader/dp/B000EW0KHW Equus - Digital Ford Code Reader (3145It has a 3 digit LCD display so that you don’t have to count flashes or beeps.. Cost is $22-$36.
Admin Dude
Jan 4, 1985
34,137
15,654
234
Box behind Walmart
You didn't say what size injectors you're running or whether or not your car is digitally tuned. If stock injectors then never mind this part.
Dump the codes as suggested above. I think it may likely confirm that you have a vacuum leak. Perhaps it's the Procomp upper and lower... They're not exactly known for quality.
I had a lot of bucking issues after I put in my TFS H/C/I. Found a vacuum leak that helped a little but it wasnt until I got an actual dyno tune at TMS that all that went away.
I'm definitely no expert. When it came to my build up I was like a blind man in an orgy. Lots of feeling around trying to find what I needed.
Decipha
215
37
39
New Orleans, LA
99% of bucking is usually due to dashpot, open up the throttle body stop 1/4 turn, should help
disregard the closed throttle voltage, shooting for .99 volts is ignorant and just wrong
19lb injectors are not gonna cut it, henry didnt put 24s on the cobra cuz they felt like, its needed
If your gonna buy injectors you might as well get 80s and tune it correctly along with a new high flow maf, that way if you ever decide to boost it later down the line you wouldnt have to retune it
