Hello together,
as mentioned in the title i´m searching for a primary metering block
for my holley 4150 carb. This part is actually build in my carb but the nozzles
for the idle circuit was enlarged with a drill. NO it wasnt me!
I recently changed the cam and some other parts on my engine so i want to tune my carb on the new circumstances. But i need a new "untouched" metering Block to get this right. So i took my carb number (4776-5) and searched in my holley book for the part number of the primary metering block. Found it: 34R8519AP, searched on holley.com to find out that this part is not more aviable!
Searched some sites (jegs, summit) for an identical block to buy but all (holley) replacement blocks are not for my 4776-5 carb! They exist for the 4766-1+2+3+46+7 Carbs but not for mine 4776-5.
Also seen some aftermarket products from proform etc but when its possibly i want to go with an holley part. Is my thinking correct that tuning it with a aftermarket block would be even more "difficulter" as with an original holley part?!
So anybody know which part will fit and where to buy? Basically i want the exact same part which is actually build in but in "untouched" shape to tune it with the correct main jets and powervalve.
thanks and greetings
Mario
Also seen some aftermarket products from proform etc but when its possibly i want to go with an holley part. Is my thinking correct that tuning it with a aftermarket block would be even more "difficulter" as with an original holley part?! So anybody know which part will fit and where to buy? Basically i want the exact same part which is actually build in but in "untouched" shape to tune it with the correct main jets and powervalve.
Mario
If you can locate what you're looking for, I'd be happy to get it for youy and ship via the US mail. It'll go in a flat rate box, which costs less than $20 I'm sure.
amnit:
