94Silverbullet Member Jan 3, 2003 488 0 17 MD Oct 29, 2007 #1 Oct 29, 2007 #1 Holley Throttle body sticking anyone have problems with this product. It's the fox body style on a sn95 car.
HISSIN50 "How long does it take to get help in here? 15 Year Member Nov 29, 1999 31,179 34 129 Oct 30, 2007 #2 Oct 30, 2007 #2 I haven't used it but is the stop screw dialed-in far enough? Also, if it has screws on the TB shaft (affixing the blade to the shaft), you might be able to adjust it. Good luck and bump for ya.
Blackened302 Active Member Jul 21, 2005 1,439 0 36 South TX Oct 30, 2007 #3 Oct 30, 2007 #3 my current TB (off the Explorer) was sticking when we did the swap (lots of gunk), so i degreased the hell out of it and it cured the problem. that may be worth a shot if everything seems to be adjusted fine.
94Silverbullet Member Jan 3, 2003 488 0 17 MD Oct 30, 2007 #4 Oct 30, 2007 #4 HISSIN50 said: I haven't used it but is the stop screw dialed-in far enough? Also, if it has screws on the TB shaft (affixing the blade to the shaft), you might be able to adjust it. Good luck and bump for ya. Click to expand... it was even moved to lessen the angle for less friction. I actually had to replace it. it was defective. Has anyone had problems with this product?
Rick 91GT Mustang Master Nov 29, 1999 9,692 95 99 PA Oct 30, 2007 #5 Oct 30, 2007 #5 David give me a call please....
94Silverbullet Member Jan 3, 2003 488 0 17 MD Oct 30, 2007 #6 Oct 30, 2007 #6 Rick 91GT said: David give me a call please.... Click to expand... I'll call shortly...
