Its in the new summit catalog, but not on their website yet, or on trick flow's.
Here's what it says:
Trick Flow's track heat 4.6L 2V SOHC intake improves performance in the heart of your 99-04 GT's powerband: 1,500-6,500rpm or 1,500-7,200rpm with ported heads. The cast aluminum intake features a 75mm throttle body inlet and symmetrical high velocity intake ports that work together to increase airflow and distribute it evenly to the cylinders. The manifold includes hardware, gaskets, and necessary accessories for bolt-on installation and it fits under stock height hoods.
PN TFS-518B0002 (bare upper)
PN TFS-51800002 (silver powdercoated upper)
PN TFS-51811002 (black powdercoated upper)
It is different from the "aftermarket" intakes that are just aluminum copies of the stock one... The throttle body bolts up in the same location, but the plenum is removed completely because the air is routed from the TB down UNDER the intake and enters the intake from the bottom. I'm buying one.
All are $799.95
All are $799.95
