I'm in the process of eliminating that annoying wheel hop. Currently I have the Roush rear springs,stock tires, and one piece aluminum driveshaft. I've purchased the Che Adjustable LCA's.
If calling a shop, they should know what to do, when I ask them to check/adjust the pinion and transmission shaft? Anything else I should have them adjust? From what I'm reading that if I choose to go with a wider tire in the back, I'll have to get this all re adjusted again?
When I purshed the Roush springs, I was told to just verify that the oem lca's are parallel with the ground,and nothing else needed to be checked?
Thanks
