homemade spring compressor
  • Thread starter Thread starter bock
  • Start date Start date Jan 23, 2006
bock
648
Montreal,Qc
Jan 23, 2006
  • Jan 23, 2006
anyone have a plan to built a homemade compressor tool to change the front coil spring ?
bcd
274
arab al
Jan 23, 2006
  • Jan 23, 2006
i put frpp c springs under mine and didn't need one. just put the jack under the a and ease it down. when it goes back in put it where you want it and jack it back up. probably wouldn't work on a stock spring but works well for lowering springs
bock
648
Montreal,Qc
Jan 23, 2006
  • Jan 23, 2006
well i need to take off the stock spring to cut them or to go with 4 cyl. ones cause with the aluminum heads and all,the front of the car is to high now.
But im thinking coil over now...
bcd
274
arab al
Jan 23, 2006
  • Jan 23, 2006
never messed with coilovers. wish i had the money to though. but if your gonna cut the stock spring you should be fine.
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
Jan 23, 2006
  • Jan 23, 2006
Cutting the springs is a bad idea. You mess up the end of the spring where it sits on the A arm or chassis. The heat generated in the cutting process can affect the spring's temper. Some 4 cylinder springs would be good for a drag car, and might even be good for the street since you have lightened the front of the car..
89white50
440
central MA
Jan 23, 2006
  • Jan 23, 2006
I did the exact same thing.
F
fiveohGT
353
Fairfax Virginia
Jan 23, 2006
  • Jan 23, 2006
coilovers really arnt THAT expensive.
bock
648
Montreal,Qc
Jan 23, 2006
  • Jan 23, 2006
i was thinking cutting a full turn of the spring with a steel saw...
but if i find 4 cyl. coils. it will be this.
TrunkFunk
Banned
Dec 28, 2005
83
A1A - Beach Front Avenue ...
Jan 23, 2006
  • Jan 23, 2006
Like richker said above.
You probably want to avoid cutting the stock springs.
They are progressive rate and we've all heard enough horror stories about ride quality after doing it.
bock
648
Montreal,Qc
Jan 24, 2006
#10
  • Jan 24, 2006
  • #10
will 4 cyl coil bring back my front equal to the rear?
look the pic.
Suspension Installing stock springs on my 86 GT
  • Canyonred86
  • May 14, 2025
Fox 5.0 Mustang Tech May 19, 2025
Mustang5L5
Front Coil Overs and Rear Traditional Springs within a Maximum Motorsports K-Member Kit
  • Habu135
  • Sep 7, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 9, 2026
Habu135
2010 GT AC issue
  • 2010torchredgt
  • Jun 28, 2026
  • 2010 - 2014 Specific Tech
2010 - 2014 Specific Tech Jun 29, 2026
2010torchredgt
2001 v6 New compressor issue
  • badmech
  • Apr 30, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Apr 30, 2026
badmech
Suspension Is somethig Wrong Here?
  • Icemanxxxv
  • Jul 11, 2026
Fox 5.0 Mustang Tech Jul 11, 2026
AeroCoupe
