Hood latch, 5.0
  • Thread starter Thread starter royalet
  • Start date Start date Sep 15, 2004
R
royalet
  • Sep 15, 2004
has anyone ever had any problems with the hood latch assembly, i have a fiberglass 5 inch cobra r hood, but it wont latch secure, any ideas
Legendary
1,925
City of Angels
Sep 15, 2004
  • Sep 15, 2004
Try adjusting the part that is bolted to the frame. Loosen the bolts and play with it. Also get some hood pins. Too many hoods flying up and damaging cars around here. They could save yours or somebody elses life.
R
royalet
  • Sep 15, 2004
hood latch
Actually i have tried to adjust the latch it and it still does not lock into placethe hood is flush it cant go down any further, do you think a goos set of hood pins would do the trick
V
v8only
2,378
22
49
Sep 15, 2004
  • Sep 15, 2004
for ultimate security I'd want the latch and pins, though there are a # of people here with pin on hoods.
I had this same problem with my glass cowl hood. the problem in your case is more than likely it is not lined up with the latch front to back wise, or even left to right. It may be lined up with the car lines, but it's not with the latch, and that's why it's not closing right. Try unbolting the hood from the firewall and shut it, you should be able to shut it in the right spot where it will fully grab. If that works, then your not lined up right.
1Slow5oh
92
Bartonville, IL
Sep 15, 2004
  • Sep 15, 2004
I know some people dont like the idea of drilling holes in their 400 dollar hood, but believe me install hood pins and screw the latch. Itll save you MUCH trouble in the future.
My hood latched perfectly when I installed my cowl hood. I drove it for a month with no problems. Even went 120+mph's. One day I was crusing at 45 and the hood flew up.
So if you want my .2 cents buy some hood pins. They are great insurance.
R
royalet
  • Sep 15, 2004
thansk alot i am going to take the hood off and see if i can lay it down and see if it latches, it seems flush though, if not i guess off to the body shop, by the way my car has been sitting for a year, and i noticed that it give off a fume smelll, i dont have cats, do you think this is from sitting, and one last thing my battery inducator fluctuates as i spress on the gas , is this normal
Legendary
1,925
City of Angels
Sep 15, 2004
  • Sep 15, 2004
When you press on the gas it spins the alternator faster and that gives out more charge. When the car idles down the charge will also slightly decrease. You pretty much get the fume smells if exhaust mods are done to the car. You'll get use to them. Just make sure it isn't a gas leak. (injectors, lines, tank)
Paint and Body Door Latch Issue
  • KRUISR
  • Oct 9, 2026
Fox 5.0 Mustang Tech Oct 15, 2026
General karthief
Hood latch connector
  • skkrtis
  • Aug 3, 2025
  • 2015 - 2023 (S550) Mustang -General/Talk
2015 - 2023 (S550) Mustang -General/Talk Aug 3, 2025
skkrtis
Drivetrain Hood latch/cable issues
  • AnthonyA1234
  • Nov 1, 2024
Fox 5.0 Mustang Tech Nov 20, 2024
AnthonyA1234
G
Engine ECU Question
  • GeorgeE
  • Oct 12, 2026
Fox 5.0 Mustang Tech Oct 19, 2026
JD1964
Drivetrain Wilwood Clutch and Brake Pedal Combo Installation - Help
  • 427stang
  • Jul 8, 2026
Fox 5.0 Mustang Tech Jul 8, 2026
427stang
