  • SN95 4.6L Mustang Tech
Hood Latch Problem
  • Thread starter Thread starter S281Sc
  • Start date Start date Aug 9, 2005
1 of 2 Next Last
S281Sc
Canaan,CT
Aug 9, 2005
  • Aug 9, 2005
Just wondering if anybody else has had problems with this or have heard of problems with it, I really have the slam the hood to get it latch the car has not had any kind of front end damage any helpful suggestions would be apreciated thanks
OrangeStang04
61
Covington, KY
Aug 9, 2005
  • Aug 9, 2005
just adjust the level that the hood latch is at, it sounds like it is sitting a little low...
9
98MACH1R
I wanna put it in so bad, please help.
Jun 6, 2005
131
  • Aug 9, 2005
have you never heard of the ten inch drop lol all i do is drop it from about ten inchs and it always closes for me
S281Sc
Canaan,CT
Aug 9, 2005
  • Aug 9, 2005
its more like 20 inch drop
C
Chopper1
91
Wv
Aug 9, 2005
  • Aug 9, 2005
Sometimes the latch will dry out and be slow to operate.Try spraying some white grease into the mechanism and see if this helps.
twogts4us
4,188
12
79
Dunedin, FL
Aug 9, 2005
  • Aug 9, 2005
Same here!
But on my wife's that doesn't work as well as on mine. On hers, I have a different technique - I lower it until it just catches the latch, then I press down firmly and it locks.
R
Ronald Jones
80
Glendale, Arizona
Aug 10, 2005
  • Aug 10, 2005
I also lower it until it just catches the latch, then I press down firmly and it locks.
csledd
Official Ovary Punching Member
1,115
Paducah, KY
Aug 10, 2005
  • Aug 10, 2005
twogts4us said:
Same here!
do you and your wife ever race? lol
I do the drop it technique also
N
n0v8or
604
Rhode Island
Aug 10, 2005
  • Aug 10, 2005
My '03 was delivered with a hood latch that required a 24" drop to close. Once I installed hood struts to get riid of that annoying 49 cent prop rod, the 24" drop did not work anymore (because of the damping effect of the struts. I shimmed the entire latch bracket (the one mounted at the top of the radiator) up 1/8" with two plastic shims. Now I just close the hood gently, then push down lightly to latch it. Still works fine after 2 years.
I have pics if it would help to see where the shims are placed.
K
Kilgore Trout
Fried or Broiled ?
4,749
95
134
Aug 10, 2005
#10
  • Aug 10, 2005
  • #10
Someone said once on this board that the GT hood is intentionally very tight due to the scoop causing drag and wanting to pull up on it... I do not think it is true but I thought I would mention it.
mr. jones1
102
NJ
Aug 10, 2005
#11
  • Aug 10, 2005
  • #11
I had to adj. the lock. just loosen the latch and rod that went down to the rad support, raise it a little and tighten.
I had to push hood down(not recommended- bad for paint and sheet metal)
now the drop method works.
GT-03
630
#12
  • Aug 10, 2005
  • #12
That is what I did with my '03 too.
IMHO, it is better than removing the pins off the latch itself.
RedBullitt
462
Morgantown WV
Aug 10, 2005
#13
  • Aug 10, 2005
  • #13
my latch was gimped from the factory, it was pinned really low and you could not adjust it at all. i took the whole latch part off and cut/sanded the pegs down and used lock nuts to hold it. worked great ever since. check the support bars right below the latch, they might be bent from all the banging the hood down, mine were lol. they can be enbent though, dont worry
S281Sc
Canaan,CT
Aug 10, 2005
#14
  • Aug 10, 2005
  • #14
Thanks alot for your suggestions ill have to try raising the latch and see how it works
K
kapuyawn
#15
  • Sep 8, 2005
  • #15
hood latch fix
Can You post pics of the shim setup on your stang?
would love to see how it should be installed.
Thanks a bunch!
N
n0v8or
604
Rhode Island
Sep 9, 2005
#16
  • Sep 9, 2005
  • #16
I have some pics I can post tonight. I cut shims from an empty black plastic VCR tape case ($1.00 at a "Dollar" store). Household scissors work fine, and allow trimming to a perfect fit under the latch assembly. I used a stack of 2 shims (about 1/8" total) to achieve a height where the hood had no up and down play when latched but was easy to close.
You have to remove the plastic radiator cover first, and then loosen or remove the latch brace rod connection from below. Finally, remove 2 (or maybe 4, it was more than 2 years ago) bolts to remove the entire bracket and latch assembly. Removing just the latch is not effective because it is pinned to the bracket at the factory after the final adjustment on the assembly line.
Test before replacing the plastic radiator cover.
GT-03
630
#17
  • Sep 9, 2005
  • #17
I did basically the same thing except I used normal Fender Shims. I got a packet of assorted thicknesses from the local auto parts store. I also didn't completely remove the two bolts which attach the latch bracket to the radiator support cross member. I just loosened the bolts enough to slip the Fender Shims between.
GT-03
630
#18
  • Sep 9, 2005
  • #18
Thanks a bunch!
Well, sorry, but what you are asking me, is to take it all back apart and do it all over again.
It really isn't all that difficult. I am sure you would not have a problem. I didn't.
N
n0v8or
604
Rhode Island
Sep 9, 2005
#19
  • Sep 9, 2005
  • #19
Links to pics.
If you look carefully in the 2nd picture, you can see the black outline of the shims under the latch bracket.
http://members.cox.net/n0v8or/radiator_cover.jpg
http://members.cox.net/n0v8or/hood_latch.jpg
sgarlic
3,085
Sep 9, 2005
#20
  • Sep 9, 2005
  • #20
You can take it to the Ford dealer (if you're under warranty,) and complain that the hood is too difficult to close.. they will do the adjusting and won't require the infamous "12 inch drop" anymore.
1 of 2 Next Last
W
2016 Mustang GT fuel tank leak
  • Waynetk16
  • Oct 8, 2026
  • 2015 - 2023 (S550) Mustang -General/Talk
2015 - 2023 (S550) Mustang -General/Talk Oct 9, 2026
gkomo
Paint and Body Door Latch Issue
  • KRUISR
  • Oct 9, 2026
Fox 5.0 Mustang Tech Oct 15, 2026
General karthief
D
What's it Worth? 76 Cobra 2
  • dulcimerbob
  • Sep 8, 2026
  • What is it Worth?!?!?
What is it Worth?!?!? Sep 12, 2026
dulcimerbob
D
T
Inside is completely dead
  • TunaCar
  • Oct 18, 2026
SN95 4.6L Mustang Tech Oct 20, 2026
DadLife0724
A
Resolved 302 oil leak when running
  • AlexM556
  • Sep 8, 2026
Classic Mustang Specific Tech Nov 1, 2026
manicmechanic007
