  • SN95 4.6L Mustang Tech
Hood question.. need answer ASAP please..
  • Thread starter Thread starter HogStang
  • Start date Start date Apr 2, 2004
H
HogStang
193
  • Apr 2, 2004
Hey there all.. I'm getting the Stalker Ram Air hood (it came with the Stalker body kit package by Cervinis) Anywhoo... I wanted to ask if I have to worry about water getting in thru the two ducts on the hood... my cold air intake is by steeda and it has a sheild over top of it and my hood scoops (ducts) aren't too close it it.. they're mainly over the middle of the engine.. maybe 3 inchs away from the pony on the engine.. but around that area.. the kit comes with 2 aluminum grates that I'm going to use so and myabe paint black becuase I'm getting that Mach grille delete keeping it all black mostly... if someone can respond to this ASAP becuase I want to make sure I'll be ok with water getting in while it's raining/being washed... thanks a lot guys.
Plus I'm getting different Mods such as a roush sway bar, and steeda pullies along with that steeda cold air intake.. can someone let me know if I'll be cool? I've been stressing over this and hopefully someone will come thru on these forums to help me get it outta my hair.. Thanks again guys.
H
HogStang
193
  • Apr 2, 2004
Can someone please respond? I'd really appreciate it.. I need to get rid of being nervous if it's for no reason.. thanks.
H
HogStang
193
  • Apr 3, 2004
Bump.
yellow5.0cobra
2,849
In the garage, On the floor.
Apr 3, 2004
  • Apr 3, 2004
You will be fine...
No need to panic.
Have fun with the body kit!
Be prepared: you will get a lot of stares!
H
HogStang
193
  • Apr 3, 2004
Thanks a lot bro.. I appreciate the reply.. and you don't know how much weight you just took off my head.. thanks again.
yellow5.0cobra
2,849
Apr 3, 2004
  • Apr 3, 2004
BTW I got a dual scoop CERVINI hood on my 94, so I know for sure.. there is no problems.
Also... you know you can buy a RAM air kit... which cost like $200 from Cervinis as well!
T
TenaciousD
320
Tampa,Fl
Apr 3, 2004
  • Apr 3, 2004
I have the stalker hood and never had a problem w/ water getting in, that was also my big concern
H
HogStang
193
  • Apr 3, 2004
Hey TenaciousD.. did you just paint the underside and also did you *not* buy a cover for under it (one of those black paper-like under cover)? Because all I'm doing is simply painting under it and leaving as be.
T
TenaciousD
320
Tampa,Fl
Apr 3, 2004
  • Apr 3, 2004
I had the underside painted "flat black", I did'nt buy a "cover" a guess you kinda need one though
H
HogStang
193
#10
  • Apr 4, 2004
  • #10
Well.. you said you had no probs with your hood right? So basically I should be ok without that cover for under it correct? I think that's what I'm getting outta all this LOL
yellow5.0cobra
2,849
Apr 4, 2004
#11
  • Apr 4, 2004
  • #11
Man you are one paranoid dude!
You dont need that "paper" stuff under your hood anyway.
H
HogStang
193
#12
  • Apr 4, 2004
  • #12
LOL Ok ok... I'll stop worrying.. I just paid a lot for this car/body work and want everything to be a-ok.
Red Dragon
310
#13
  • Apr 5, 2004
  • #13
I saw one at a car dealer and the water going into the engine messed up the ignition. If you start to get water down around the coils, you will have problems. Just ask the guys that have washed their engines with a hose and then it either would not start or it skipped a lot. As for the guys that have them and it is fine, well..... you can't knock success. But I personally have seen one that messed up. I also don't see why somebody would want to run it open. I guess it could remove some hot air out of the car. But a stock car won't realize any benefit; as the engine was designed to run in a closed environment.
My guess is that it will run fine if the coils are sealed good. But expect to have some metals parts start to rust in the engine compartment.
I have a similar hood and I run mine closed. Dry is good IMHO. I have a CAI kit so my engine gets cold intake air.
Enjoy the new hood. It will get a lot of looks. Too many at times!
H
HogStang
193
#14
  • Apr 5, 2004
  • #14
What could I use to plug them? The kit didn't come with anything except 2 aluminum grates that I'm having painted black.. I want to use the aluminum grates still.. but any ideas on what to use to plug the open holes with the grates?
T
TenaciousD
320
Tampa,Fl
Apr 6, 2004
#15
  • Apr 6, 2004
  • #15
you dont want to plug the hole it will look stupid, plus your car will resplond alot better to all the extra air being pushed under your hood, as for water getting in, i've had mine for almost 2yrs no problem.
E
2007 GT Stalls when lights or a/c turned on
  • ejscarfo
  • Jun 22, 2026
  • 2005 - 2009 Specific Tech
2005 - 2009 Specific Tech Sep 26, 2026
manicmechanic007
H
New kid on the block
  • HydraX
  • Mar 22, 2025
  • The Welcome Wagon
The Welcome Wagon Mar 22, 2025
HydraX
H
For Sale 3-owner 1987 Mustang GT, $18K obro, Lancaster CA
  • Bill Cool
  • Oct 6, 2024
2K
Fox Body Mustangs For Sale (1979-93) Oct 13, 2024
nickyb
SN95 Issues with Cervini's Ram Air Hoods in the rain?
  • Chythar
  • Apr 7, 2023
3K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Apr 20, 2023
Chythar
SOLD SOLD!!!! 1993 Notchback Roadracer For Sale. She's a beast!
  • Boydster
  • Apr 25, 2025
Fox Body Mustangs For Sale (1979-93) Apr 25, 2025
Boydster
