I just completed the install of my new 408 storker. As expected I am having extreme problems with hooking it up. My current setup on my 68 Mustang Coupe is the following:
1. 9", 3:50 gears with open differential (soon to be a Detroit Locker, 4:11)
2. Rancho 9000 series, 9-way adjustable rear shocks
3. 4 1/2 leaf springs from Mustang Plus
4. CalTrac bars
5. Comp Engineering 3-way adjustable front shocks
6. 620 front springs (1" drop) from Mustang Plus
7. 1" font sway bar (unhooked when drag racing)
8. Subframe connectors
9. 6 point cage
10. MT ET Street Radials on rear (275/65/15) running 20 psi
11. 3500 rpm stall
I orginally bought the suspension kit from Mustang Plus when I thought I was going to be running a mild 302. Since them I went with the torque monster 408 that is shreading the tires.
I am thinking about removing the second leaf (second biggest one)from the rear to help loosen it up. I also thought cutting the bands that tie the leafs together behind the rear axle would help the spings separate which would reduce the spring rate. As of now if you jump on the rear it may move an inch or two.
Finally I have some 6 cyclinder front springs that I am going to cut one coil off of to give it the stance I want. This should help transfer the weight. I
Any opinions of my setup...I need help!?? What can I do to improve the setup without spending tons of money (not a 4-link)? How do I "tune" the suspension? Anything would help...it's my first time with this type of setup.
I appreciate all of your help. I am always impressed with the knowledge people have on here. We can all learn a lot from one another.
4. CalTrac bars
9. 6 point cage
11. 3500 rpm stall
