like other said, a 1.5 to 2" extension pipe. then a tee fitting. adapter for gettin the senders in the Tee. you kinda have to plumb it in, in order or you wont be able to get it to fit. try it dry first, then dope the fittings and do it. make sure the fittings are tight enough.
good luck.
