jeff, even griggs racing(yes i talked to them about the gr350 suspension system) will tell you that their suspension for the classic mustangs is based on the fox body suspension. yes they do eliminate the strut, but the suspension is still based on the fox body. it does however have far more adjustability than the factory suspension systems do. but for the money i would rather mod the classic suspension in much the same way that historic and opentracker mod theirs. they get excellent results with budget operations, and modified stock parts proving you dont need high dollar suspension systems to get great handling. about the only change to the suspension system i might make to my 66 coupe beyond stock is the installation of a martz chassis four bar rear suspension.
again i will say, mod motors are neat, and can make alot of power, and modern suspensions are good for what they are, and aftermarket suspension systems are also very good. but why spend the money on a daily driver? it is a waste of good money. look at the cost. an early 2v mod motor runs around $2500. want a four cam? try better than $5000 for a run out motor. for $5000 you can buy a new dart block, and new top of the line aftermarket cylinder heads, intake, stroker rotating assembly, and decent cam kit, and assemble a very healthy 393w motor, that can handle as much or MORE power than any mod motor block can. you then save a bunch of money by not having to swap the suspension over to a mustang ll style or griggs style suspension because your mod motor only have a rear sump oil pan option, where as a windsor based engine can have a front sump pan if you choose.
with the right mods, any car can be a very good performing daily driver in all driving regimes, and you dont have to spend the money on the newest stuff. you just have to know how to tune the suspension, and build the engine.
