Horn beeps twice but both doors closed
does dome light goes out? Keyless monitors domelight to see if door is shut. U replaced it, and now car thinks door is oepn. I say you got short or wire contacting metal or someting like that at your dome light
mity2 said:
humm
check your door switch, make sure that they are not corroded or something. Othewise, donno what to tell you man
Let's mix the 2...I've had this problem on both my Stang and my '98 Taurus. The Taurus had the alarm horn; on the Stang it was the dome light not shutting off. Same fix...soak, and I mean SOAK the door latches with WD40. Fixed 'em both :nice:
