Horrible exhaust leak - Need the best route to fix it.
MustangLife
1,285
44
Chattanooga, TN
My cars bottomed alot due to the speed bumps and my apartment complex. All of my exhaust bolts are tight as I can get them. But I have 2 horrible exhaust leaks. I know two cause one just developed a few days ago. I went almost 2 years with no exhaust leaks.
So whats the best route in fixing an exhaust leak? Its a Pypes Catted x. I just want to make sure all exhaust leaks are fixed when i take the car off of the jackstands. The leak is sounding like its in x-pipe area to front of the catback area. I only have 1 pair of jack stands.
Thanks in advance
Josh
PS Is there anything I can put in the areas where the pypes join together.
I would say loosen them and check alignment ::shrug::
Best to determine for sure where it is coming from before you start... you can usually get down there and listen and if u can reach under feel around the connections for the leak (don't touch them as they will be hot)
