  • 1994 - 1995 Specific Tech
horrible gas milage
  • Thread starter Thread starter BULLITTSTANG95
  • Start date Start date Jul 2, 2005
BULLITTSTANG95
97
Oklahoma City
Jul 2, 2005
  • Jul 2, 2005
i just figured up my gas milage for the city and it is horrible and i need to figure out why. for the city i figured it to be 10.5 miles to the gallon and it seems to be running really rich. when installing my exhaust i pulled the #1 plugs and it was all wet and smelled like gas. i have no check engine light coming on. but it seems to me that a efi 5.0 with 3.73 and pretty much stock motor should be getting better gas milage than this. any input is greatly appreciated
BULLITTSTANG95
97
Oklahoma City
Jul 3, 2005
  • Jul 3, 2005
HGFireHazard
460
Michigan
Jul 3, 2005
  • Jul 3, 2005
I would start by at least checking the computer to see if it has any codes stored in memory or not. From there the list only gets bigger.
18mustangs
533
Virginia Beach, VA
Jul 3, 2005
  • Jul 3, 2005
Pull your codes first and see if anything is wrong. You also might want to look into new O2 sensors as I got 10 mpg in town when mine went bad after my LT header swap. If you haven't done a good tune up in a while you also might want to get a new cap and rotor, new plugs, wires, and fuel filter. Cleaning the MAF element and IAT sensor would also be a good idea.
Tim
F
Difference between 83-86 EFI and 87-97 gas tanks?
  • ForeverDrivin
  • Mar 30, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Mar 30, 2026
ForeverDrivin
F
idles perfect then jolts and cuts out when put into Reverse or Drive.
  • shanesstangs
  • Mar 12, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Apr 27, 2026
General karthief
J
Engine 4.6 Running rough at half throttle
  • jake411
  • Aug 3, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Oct 20, 2026
DangStitches
D
Running very very rich
  • 2esoteric
  • Oct 31, 2025
Fox 5.0 Mustang Tech Oct 31, 2025
'04 V6 running rich excessively on both banks
  • 04DSGVert
  • Oct 26, 2025
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Oct 27, 2025
04DSGVert
