Horse Power
fast4cheap
82
north carolina
If you dont have enough compression I dont care if you jack your timing to the moon, racing gas will hurt you not help you, this is a proven fact. also more timing doesnt make more power, there is a ideal timing curve for every engine. most engines need no more the 34-38 degrees of timing to make it's most power,regaurdless of how much octane you pump to it. Ideal ignition curve depends on many things such as combustionchamber effecency,i'e the quench, bore of the engine, stroke, rpm, piston design, you know all those things that help control detonation, SO NO YOU CANNOT PUT 110 GAS IN YOUR STOCK RIDE BUMP THE TIMING TO 40 DEGREES AND EXPECT A GAIN. ITS NOT GOING TO HAPPEN.
