1968 coupe, 289, running 3G 95 amp alt from RJM Injection.com....dual V belts. i have some high pitched sqealing on mid rpms and alternator is really hot to the touch after about 20 minutes with the engine at idle.
wires are hooked up correctly, 175 mamp fuse and harness connections are correct as well. Amp is charging battery with no electrical drain.
Are the V-belts not enough to stop from squealing? Do i need to run a serpentine setup then? Why is the 3G so hot?
I'm thinking about scraping this whole "upgrade" and going back to the old style alt.
