  • 1994 - 1995 Specific Tech
How bad is Code 511 ??
  • Thread starter Thread starter Venom351R
  • Start date Start date Aug 20, 2009
Venom351R
4,548
41
98
MAINE
Aug 20, 2009
  • Aug 20, 2009
Ive had a check engine light since last weds.
Scanned the codes tonight threw a 111,113 and 511
111- System Pass
113- Intake Air Charge Temperature sensor above maximum voltage -*40
511- Read Only Memory (ROM) Test failure.
Venom351R
4,548
41
98
MAINE
Aug 20, 2009
  • Aug 20, 2009
The tuner said its caused from the chip and that it is normal. Im leaving the battery unpluged over night to see if it clears the 113 code b/c it has a new IAT sensor in it
Chythar
Recently finished repairing my rear
20+ Year Stangneter
Aug 26, 2004
2,373
140
113
Foothill Ranch, CA
Aug 20, 2009
  • Aug 20, 2009
Correct, 511 is thrown if you have a chip. You may still need to clear the codes manually; I believe some codes are not cleared by disconnecting the battery.
Venom351R
4,548
41
98
MAINE
Aug 21, 2009
  • Aug 21, 2009
How do you clear them manually b/c I left the battery unhooked all night and they did not clear.
It also has a 998 (running in failure mode) when its running, whats that one?
Chythar
20+ Year Stangneter
Aug 26, 2004
2,373
140
113
Foothill Ranch, CA
Aug 21, 2009
  • Aug 21, 2009
If you have a code reader then it has an option to clear the codes. If you're using the "count the blinks" method, I'm honestly not sure how to clear the codes. I've always used a code reader. Perhaps some one else can pitch in on this one.
cjones
1,561
Avondale, AZ
Aug 23, 2009
  • Aug 23, 2009
did the codes not clear or was the 113 code not fixed?? disconnecting the battery will erase a 113 as well as the KAM.
to clear just the KOEO (continuous) codes when using the 'blinking' method. disconnect the jumper during the test. the hard codes are suppose to clear after completing the self-test.
if you jumper the connector do you get a 112 or 117??
Venom351R
4,548
41
98
MAINE
Aug 23, 2009
  • Aug 23, 2009
Im using a code reader, I dont see where it says to clear the codes.
I left the battery un plugged over night and it still throws the 113 code
cjones
1,561
Avondale, AZ
Aug 23, 2009
  • Aug 23, 2009
Venom351R
4,548
41
98
MAINE
Aug 24, 2009
  • Aug 24, 2009
I dont know what jumping the connector is, all I did was plug in the scanner and posted the codes that it threw at me and leaving the battery unhooked didn't do anything to erase them.
cjones
1,561
Avondale, AZ
Aug 24, 2009
#10
  • Aug 24, 2009
  • #10
remove the Intake Air Charge Temperature sensor. place a jumper wire (small wire or paperclip) across the terminals of the wiring harness connector in place of the Intake Air Charge Temperature sensor.
rerun the codes. did you get a code 112??
disconnecting the battery for 15 minutes will erase the codes but if the problem has not been fixed then the code will reappear.
Venom351R
4,548
41
98
MAINE
Aug 25, 2009
#11
  • Aug 25, 2009
  • #11
did not try that but I will
  • Gulftown980x
  • Jul 29, 2026
  • SN95 4.6L Mustang Tech
squeak93
M
01 mustang 3.8 fuel pressure issue
  • Mhaley2006
  • May 29, 2026
1996 - 2004 SN95 Mustang -General/Talk- Aug 9, 2026
JohnKay
J
J
Thanks for the information on codes 31,34,44 and 94!
  • JK86LX50
  • Mar 5, 2025
  • The Welcome Wagon
The Welcome Wagon Aug 5, 2025
gkomo
M
Progress Thread 1993 Ford Mustang 5.0 convertible stock manual - ODB Codes shows running lean
  • mcalvo
  • Feb 11, 2025
Fox 5.0 Mustang Tech Feb 22, 2025
AeroCoupe
SURGING IDLE / NO IDLE CHECKLIST FOR 1996–1998 MUSTANG GT (4.6L 2V) - Work In Progress
  • Noobz347
  • Aug 30, 2025
1996 - 2004 SN95 Mustang -General/Talk- Aug 30, 2025
