Modular2v said:with tfs heads your are DEFINETLY going to have to have piston work done
Jason 302 said:Put some ported E7's or GT-40's on (probably have to flycut pistons, it's an 86), put a standard street cam in (E303, TFS #1), a aftermarket intake (Cobra, Edelbrock), with all the goodies (throttle body, underdrives, 4.10 gears), don't forget subframe connectors. Put some slicks on and launch the hell out off it!
85mcLaren said:What Daggar says is true for most 86s. The TW heads will give better performace on the 86s due to the higher compression. But I will tell you the old 'cop-out' story and check the P/V clearance with any head (TW or E-7s) on an 86. The tolerances vary on every motor and on an 86, I would defenitely check......
Paul Perreca said:Is this true? (how bout mass air and A9L comp?) If that is true, than my 88 (after mass conv) with ported polished E7's, cobra upper and lower, 70mm throttle, 76mm C&L, e 303 cam, and 3.55s could possible run in 12's??? That would be bad ass - but just doesnt seem realistic. 12's is fast.
