I get a clunking noise occasionally when my AOD shifts. Doesn't feel like the tranny is going bad, wondering if it is U joints or tranny mounts. Anyone know how to tell if either are bad?
Get under and note if there is any slop in the joints when the adjacent DS runs are turned toward and against eachother. Note rusty areas on the joints or signs of a loose cap (suggesting bad needle bearings inside the cap).
Trans mount - visual inspection and pry on it and note movement. Dont forget to check crossmember mounts too.
Ive had a clunk noise before (in a diff car but still), and all there was to the fix was tightening the tranny mount even more. Hopefully you'll be as lucky.
Try to move the drive shaft back and forth with a quick motion and watch the u joint. If it has any loose action or wobble it is bad, there should be no play in the u joint. My experience has always been that the u joint squeaks.
