  • 1994 - 1995 Specific Tech
How Did You Torque Your Driveshaft?
  • Thread starter Thread starter redsn95gt
  • Start date Start date Apr 24, 2011
R
redsn95gt
143
  • Apr 24, 2011
Having hell of a time of finding a wrench combo that will fit the driveshaft companion flange bolts with either of my torque wrenches and still have a solid contact. Everything kinda leaves it at a nasty angle, I really don't want to strip one of these bolts. What did you use to get a good grip on those bolts?
Thanks
revhead347
Apparently my ex-husband made that mistake.
20+ Year Stangneter
Jun 14, 2004
9,303
1,647
214
Acworth, GA
Apr 24, 2011
  • Apr 24, 2011
12mm wrench is all you need. I know there is a torque spec, but it's not a critical area. Just make sure you put plenty of loctite on them. I've never torqued them down with a torque wrench.
Kurt
Reactions: Scrapla347
Adam95GT
2,564
Burlington, NJ
Apr 24, 2011
  • Apr 24, 2011
I just made mine tight.
final5-0
Mustang Master
Apr 6, 2003
6,817
12
79
DFW Texas
Apr 24, 2011
  • Apr 24, 2011
If the've never been off ... the're gonna be very tight :Word:
Some heat from a torch will loosen that wretched loctite
I hate that stuff
Give me the Good Ole Days when all they used was a lock washer
Grady
BlownFiveLiter
have car, will race....wait, it doesn't run
18
108
Chicagoland
Apr 24, 2011
  • Apr 24, 2011
A swivel socket and a torque wrench will work. I believe the torque spec is 75-85 lb. ft. and as mentioned above, it's a 12 point 12mm bolt.
revhead347
20+ Year Stangneter
Jun 14, 2004
9,303
1,647
214
Acworth, GA
Apr 24, 2011
  • Apr 24, 2011
You can't use a swivel with a torque wrench. If you absolutely have your heart set on a torque wrench, you can jack the car way up, and lower the axle all the way down. Then you can get in there with about a 12" extension. Not worth it in my opinion.
Kurt
R
redsn95gt
143
  • Apr 25, 2011
Thanks for the ideas guys. So far a box wrench has been the only real champ on tightening these 4 bastards. I put on a multi point 12mm with a short extension to try to reach around the edge and its just not flush enough for my liking to give it a real go. Of course you gotta keep the wheels locked down during the whole operation so that means they need to be on the ground for me. Such a not fun way to finish a car.
divit250r
314
Columbia City, IN
Apr 25, 2011
  • Apr 25, 2011
I used a box end wrench on the head, and slipped another box end wrench over the open end of that wrench as a cheater bar. Works to break them loose the first time, and tighten the crap out of them ever since.
wheelyman19
155
Apr 25, 2011
  • Apr 25, 2011
You first might wanna jack the car up and turn the drive shaft so you car get the wrench on it flush. There's a certain spot that the socket will fit flush in but you gotta have it jacked up and in neutral so you can turn the drive shaft. A car lift with a dewalt cordless impact is ideal lol.
Last5.0
404
Apr 25, 2011
#10
  • Apr 25, 2011
  • #10
Yup, then after you turn it to that sweet spot put the e-brake on to help keep it from turning or put it in gear (forward or reverse depending on which way you are turning the bolts...loosening or tightening).
revhead347
20+ Year Stangneter
Jun 14, 2004
9,303
1,647
214
Acworth, GA
Apr 25, 2011
#11
  • Apr 25, 2011
  • #11
I just jamb my feet up against tires. Saves time, unless you have someone else to keep pull the e-brake for you.
Kurt
Last5.0
404
Apr 27, 2011
#12
  • Apr 27, 2011
  • #12
Kurt
That works too if you're not laying on a creeper...lol
I always forget about the creeper rolling and half the time when laying under the car and I first go to remove a bolt I end up just pulling myself further under the car
R
redsn95gt
143
#13
  • Apr 27, 2011
  • #13
I put the tires on a couple blocks, that was more than enough clearance for me to get under there and hit it with a box wrench and some locktite. I was damn near bending the wrench while tightening, so i hope it holds.
revhead347
20+ Year Stangneter
Jun 14, 2004
9,303
1,647
214
Acworth, GA
Apr 28, 2011
#14
  • Apr 28, 2011
  • #14
I gave up on creeper's years ago. About all they are good for is jambing your arm skin under the wheels.
Kurt
J
Exhaust manifold to Y-pipe nut & stud dimensions?
  • joeybuddy96
  • Jul 7, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Jul 9, 2026
joeybuddy96
J
Replace the entire AC charge port
  • from6to8
  • Feb 22, 2025
1994 - 1995 Specific Tech Feb 22, 2025
from6to8
Car shakes when taking off help???
  • STANKYstangs
  • May 10, 2026
1996 - 2004 SN95 Mustang -General/Talk- May 27, 2026
LILCBRA
Drivetrain 83’ Glx convertible C5 Trans help!
  • JacksonJared2113
  • Dec 25, 2025
Fox 5.0 Mustang Tech Dec 26, 2025
JacksonJared2113
New misfire after replacing valve seals/springs.
  • SpeedofDarkness
  • Aug 24, 2025
SN95 V6 Mustang Tech Aug 24, 2025
SpeedofDarkness
