I went through the heads, before I read your reply, and tightend each stud down when the valve was closed, until the rocker would no longer have any play in it, then 1/2 turn more. As I understand, that's what the directions said. But now, the car won't start. I'm so confused...I set the timing around 5* and yesterday it would run, but only if I held it around 2000rpms; and at least a couple of valves were ticking. After adjusting the valves as I described, I can't get the car to start.
