Engine How Do I Change From Tfi Distributor To A Duraspark?
scottda
We have an 1989 Fox with a failing TFI distributor and we'd like to change over to a DuraSpark distributor. Does anyone have guidance on how to do this? Which distributor gear do I use? the one from the TFI we have now or the DuraSpark one? What about wiring to the MSD 6a box?
The DuraSpark unit is not compataible with EFI, it has a mechamical spark advance. The EFI distributor has no spark advance mechanism, it uses the computer to control the spark advance.
msd-ford-installation-w-harness-gif.71658
msd-ford-installation-wo-harness-gif.71659
Instead of using the battery negative terminal, attach the heavy gauge black wire to the body ground point by the windshield washer filler.
The battery common ground is a 10 gauge pigtail with the computer ground attached to it.
Picture courtesy timewarped1972
