How do i check input shaft endplay!
  • Thread starter Thread starter mr.b
  • Start date Start date Apr 25, 2005
M
mr.b
214
  • Apr 25, 2005
going to be doing a bearing retainer soon. What do i need to do to check the endplay and what are the tolerances of it? I already have a magnetic stand and dial indicator. I am guessing just move the input shaft back and forth and check the amount of movement?
Stang8URMPRT
1,100
Daytona Beach, FL
Apr 25, 2005
  • Apr 25, 2005
The endplay is something like .002-.005.. which is almost TIGHT... Go with a set of shims that has a LITTLE bit of play, then step up to the next size, inwhich it should leave almost no to no play.
M
mr.b
214
  • Apr 25, 2005
Stang8URMPRT, you left out the part about how to check it?
Stang8URMPRT
1,100
Daytona Beach, FL
Apr 25, 2005
  • Apr 25, 2005
I've never checked mine, just left it tight. Never had a problem.
J
Suspension Foxbody mustang Steering shaft issue
  • Jakub2537
  • Sep 5, 2026
Fox 5.0 Mustang Tech Sep 11, 2026
gkomo
P
2002 T5 transmission vibration issue
  • puffoo
  • Feb 22, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Feb 22, 2026
puffoo
P
K
3.8 T5 & Bellhousing to 1987 Lincoln 5.0
  • ks65stang
  • Mar 2, 2026
  • Other Auto Tech
Other Auto Tech Mar 3, 2026
Drive Shaft/Rear Diff Issue on 2014 GT
  • DudeStang
  • Jun 16, 2025
  • 2010 - 2014 Specific Tech
2K
2010 - 2014 Specific Tech Jan 21, 2026
gkomo
J
88 Foxbody 5.0 Driveshaft Issue! Need Help
  • James Hood
  • May 1, 2025
Fox 5.0 Mustang Tech May 1, 2025
AeroCoupe
