how do i fix this! (pic)
carbed87
215
the rest of my car is perfect, but im kinda out of ideas as to go about fixing this. all i can think of is wire-wheel all the **** off and spray can it afterwards to prevent further corrosion. any other ideas would be good too.:D
yeah thats my guess too.. id use a brilo pad and clean it up, some sand paper and after you paint it... open your doors after every wash... and towel dry your doors off... along with the door wall inside the car aswell... keeping both dry after washes and rain storms will stop it from rusting again...
I don't care what anyone says or what you heard.....Rust will come back at some point if you cover it up with something....it will rot away underneath whatever you cover it with. Sand blast or wire wheel that to bare metal than use some primer and paint it.
a little wire wheel on a angle die grinder would be perfect for than.....unless you have access to a sand blaster
:Word: best thing to do is take the factory seam sealer off (that glue type stuff at the bottom) and hit it with a sandblaster or a small grinder. depending on how bad the rust is you might have to do a little trimming and weld a new strip of metal on the botom edge of the door. just my .02:nice:
Sand and rattlecan (matching color), realistically if the doors have signs of rust then multiple areas will as well. When and if you are going to resto the car then you can do full on rust repair but most likely you're looking for a fast method that will last and go unnoticed. Clean it good, rattlecan it and after it cures throw a thin layer of grease on top....clean and reapply every couple months and you'll likely never see rust again and no one will notice the repair.
lol it sucks that this is the only place the damn thing has rust, but this seems to be a very common place for it. oh well, i guess i'll just trade it in on a scion. the degree of personalization for those cars are just amazing!
lolj/k
i had the same issue with my car so i just blasted it with some fine grade sand and then put some paintable rino liner on it and painted over the treated part. This works better and will out last any other part of the body also did the same to the engine bay.
Whatever you do, don't underestimate it. My doors looked like that when i joined this forum in '03....they're rotted to hell and back now and are getting replaced.
Also while you're at fixing it, you might wanna check out the quality of your dew wipes....the little squeegies that contact the windows on the outside. That's usually the cause of rusted out doors because their job is to prevent water from leaking down into the door and sitting, causing rust. Mine are shot, so now my doors are shot.
