  • 1994 - 1995 Specific Tech
how do i install gears???
  • Thread starter Thread starter MI95Cobra
  • Start date Start date Feb 13, 2007
MI95Cobra
451
Oklahoma City
Feb 13, 2007
  • Feb 13, 2007
i know i've asked this before but in the next few weeks i'm planning on installing my 3:73 gears and i want to know step by step on what i need and how to install them...please any help will be grateful....
The Green GT
No 13 year olds are safe around me.
1,269
Louisiana
Feb 13, 2007
  • Feb 13, 2007
Theres a good bit of info here.
http://www.angelfire.com/theforce/5ohcpa/cpa5ohtech001.htm
R
red95gtconvert
382
Ponca city, OK
Feb 13, 2007
  • Feb 13, 2007
Drive up to Ponca city and I will help you put them in, you'll have to buy the beer after we get them in though . There is a few tools that you must have to do the install. Inch/pound and foot/pound torque wrench's, a dial indicator with a magnetic base, a bearing seperator and a gear oil pump. I'm lucky enough to have access to all these tools and they are required to do a good install.
mo_dingo
20+ Year Stangneter
Aug 26, 2003
3,031
Tucson, AZ
Feb 13, 2007
  • Feb 13, 2007
Here is my writeup
http://forums.stangnet.com/showthread.php?t=479678
Good luck. The most important thing to tell you is to read each install article several times over. The one that Green GT posted was a big help. If there was something that confused me, I re-read that article and I usually figured it out. If you have any specific questions let me know.
Scott
MI95Cobra
451
Oklahoma City
Feb 13, 2007
  • Feb 13, 2007
awsome, thanks guys.....red95gt how long would it take to install????
I
igotyofire
774
Southern California
Feb 13, 2007
  • Feb 13, 2007
i hope u have a press too....
black94gt50
112
  • Feb 13, 2007
a press is a must
R
red95gtconvert
382
Ponca city, OK
Feb 14, 2007
  • Feb 14, 2007
I can do it in about 4 hours now, a press is really only necessary if you change the carrier bearings out. I learned a real nice way to seat the pinion bearing that doesn't require a press, but if needed I have one at work that I can use on a sunday only type deal The thing that will hold up progress is that all of the nuts and bolts are usually very tight if it has never been tore down before which can slow things down considerably. The trick to doing a good job is to measure and check everything 4 times before reassembly.
I
igotyofire
774
Southern California
Feb 14, 2007
  • Feb 14, 2007
i hope u have a ford gearset, just makes it easier to setup the way ford set them up with the stock shims and more then likely quieter. 2nd id recomend changing out all the bearings now since ur working on it anyways. Most peoples 94,95 stangs have quite a bit of miles on them now. My car had only 111,000 miles and my rear end was quite noisy and the inner race was all gashed up. So id say its not a bad idea to change now. Also i dont know if u plan to change the speedo gear for speedometer correction but it seems my cobra already had the yellow 7 tooth outputshaft drive gear needed for a proper match with 373s. i took pics and need to clarify for others. and i know my car was never touched which is strange. Maybe only the gt came with the 6th or 8 tooth whichever it was.
OrangeMustangGt
1,976
Cape Cod, MA
Feb 14, 2007
#10
  • Feb 14, 2007
  • #10
i can do it without a press....just takes a bit more time
also hog out another pinion bearing so its easy to set shims.
80% of the time you will get a good reading using same depth as stock shims
mo_dingo
20+ Year Stangneter
Aug 26, 2003
3,031
Tucson, AZ
Feb 14, 2007
#11
  • Feb 14, 2007
  • #11
I you don't replace the carrier bearings, all you need is the "large bearing separator" that harbor freight sells for $10 to get the pinion bearing off.
My first time, using a lift, I was done in 4 hours.
Scott
3.08 gears with a manual trans
  • limp
  • Aug 27, 2026
  • 2 3
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 14, 2026
Qtrhrse23
K
Drivetrain '87 5.0 Installing New Ring Gear and Pinion - Pattern Questions
  • karhoot
  • Apr 23, 2026
Fox 5.0 Mustang Tech May 9, 2026
Mindseye007
Sound deadener install
  • limp
  • Jun 15, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 17, 2026
limp
M
Misfire
  • Mike3
  • May 30, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 30, 2026
Mike3
M
Hammer shifter problems
  • 387lx
  • Apr 9, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Apr 11, 2026
General karthief
