How do I make these fit!!!
  • Thread starter Thread starter 5.0fox
  • Start date Start date Apr 25, 2007
5.0fox
410
buckley/enumclaw wa
Apr 25, 2007
  • Apr 25, 2007
I got a really nice set of valve covers for really cheap and wanna make them fit. They are fabbed aluminum with a billet rail and no holes in them. I picked up a Breather setup and drilled one for it. then I go to install them and realize the metal hardlines for the fuel rail feed wont clear in the front! But I knew there was a fix for that... I could use these http://store.summitracing.com/partdetail.asp?autofilter=1&part=RUS%2D651104&N=700+400081+315885+115&autoview=sku
So that leads me to one more problem... Now how can I mount a fuel pressure guage? I thought maybe I could run sn95 fuel rails because they have the schrader port on them instead of on the feed line. but it says those fuel lines only work for 86-93 rails.... Now im lost!
What setup can I run that will allow me to use soft lines in the front for valve cover clearance but also allow me to use a fuel pressure guage? Any input will be greatly appreciated!
5.0fox
410
buckley/enumclaw wa
Apr 25, 2007
  • Apr 25, 2007
TTT come on guys I need some help!
LEE93COBRA
1,929
Alabama
Apr 25, 2007
  • Apr 25, 2007
ok I think I am confused. Am I understanding that your valve covers are interfering with your fuel lines coming up from the bottom of the engine compartment.
If that is all it is, loosen the head bolt that has the fuel line bracket. Remove the attachement and replace the bolt. Then you should be able to move the lines where you need them to be
5.0fox
410
buckley/enumclaw wa
Apr 29, 2007
  • Apr 29, 2007
there hard lines all the way and theres not very much room behind the alternator. I dont think they will bend much at all!
LEE93COBRA
1,929
Alabama
Apr 29, 2007
  • Apr 29, 2007
Did you take them loose from the head like I mentioned?
By the way, if there is not enough gap between the valve cover and altenator for the lines to at least sit in then the covers will not work.
5.0fox
410
buckley/enumclaw wa
May 2, 2007
  • May 2, 2007
Ya I undid them from the head. I could plug them in if I bent them but thats not what I want to do!
Mustang78
486
Aberdeen, WA
May 2, 2007
  • May 2, 2007
if you end up selling the valve covers for the correct set, send me a PM..sorry i have no useful info to add, except i have a stock fuel rail if you bend yours beyond repair
~Mark~
M
01 mustang 3.8 fuel pressure issue
  • Mhaley2006
  • May 29, 2026
1996 - 2004 SN95 Mustang -General/Talk- Aug 9, 2026
JohnKay
J
Fuel rail help
  • stang9150
  • Mar 3, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Mar 5, 2026
stang9150
Fuel 87 5.0 Fuel rail lines
  • Mcmahst
  • Jan 21, 2025
Fox 5.0 Mustang Tech Feb 11, 2025
Mcmahst
A
Resolved Fuel pressure high at 52 new FPR same thing
  • afjLX
  • Dec 28, 2024
  • 3 4 5
5K
Fox 5.0 Mustang Tech Jan 11, 2025
AeroCoupe
Engine Motor swap from a 2003 Explorer
  • 1996mustang new
  • Oct 9, 2025
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Oct 16, 2025
squeak93
